ldap authentication backup
Post by nicola.piazzi »
Using this our efa is able to get mail for our exchange real users rejcting others :
relay_recipient_maps = ldap:/etc/postfix/ldap_relay_recipient_maps.cf
1) If I send to an exiting email and this is correct :
Mail sent successfully
2) If i send to a non existing email i get the error :
Error: RCPT TO: <nicola.pizzi@gruppocomet.it> failed '550:5.1.1 <nicola.pizzi@gruppocomet.it>: Recipient address rejected: User unknown in relay recipient table'
3) If there is a configuration error (config file lost or ldap unavailable or ldap user password change , ...) it give a lookup failure
Error: RCPT TO: <nicola.piazzi@gruppocomet.it> failed '451:4.3.0 <nicola.piazzi@gruppocomet.it>: Temporary lookup failure'
is possible to have a DELIVERY (obviously for verified and unverified address) in case of ldap failure ?
Re: ldap authentication backup
It doesn't look like it: http://www.postfix.org/postconf.5.html# ... pient_maps
It appears to be an all or nothing matter.
So, you're choices are:
1/ make sure your ldap never goes down
2/ have a High Availability ldap setup, either via HAProxy or maybe round robin DNS
3/ configure a second fallback map for when LDAP is not accessible - that could be another LDAP server if you dont like #2.
4/ use user/password smtp authentication
5/ ?
