Issues updating from 3.0.2.2
G3 Support
Post by G3 Support » 04 Jan 2021 14:00
Hi All,
I am trying to update 3.0.2.2
I get this error
[EFA] Good you are root
Setting up Update Process
Determining fastest mirrors
Error: Cannot find a valid baseurl for repo: base
YumRepo Error: All mirror URLs are not using ftp, http[s] or file.
Eg. Invalid release/repo/arch combination/
removing mirrorlist with no valid mirrors: /var/cache/yum/x86_64/6/base/mirrorlist.txt
Update to Version 3.0.2.3 FAILED. Updates cancelled.
Please visit https://www.efa-project.org for more information.
I have run the yum clean, check-update and update commands but the yum update gives me the same All mirror urls error.
Any idaes?
Re: Issues updating from 3.0.2.2
Post by henk » 04 Jan 2021 19:18
Efa 3.0.2.3 was released 20 May 2017
Move to the present is the best idea.
