Seeing Line references path below legacy directory notices
marjohn56
Post by marjohn56 »
I've just 'noticed' the following in my system logs, probably because I've finally gotten around to hooking up EFA to my syslog server. All appears to be running OK, just wondered if it's something that needs to be dealt with.
020-10-11 15:25:05 Daemon Notice 10.4.12.31 Oct 11 15:25:05 mailgate systemd-tmpfiles[6342]: [/etc/tmpfiles.d/opendmarc.conf:1] Line references path below legacy directory /var/run/, updating /var/run/opendmarc → /run/opendmarc; please update the tmpfiles.d/ drop-in file accordingly.
2020-10-11 15:25:05 Daemon Notice 10.4.12.31 Oct 11 15:25:05 mailgate systemd-tmpfiles[6342]: [/etc/tmpfiles.d/opendkim.conf:1] Line references path below legacy directory /var/run/, updating /var/run/opendkim → /run/opendkim; please update the tmpfiles.d/ drop-in file accordingly.
Re: Seeing Line references path below legacy directory notices
Just a deprecation warning, you can disregard. I'll make a note to push out an update to fix this automatically.
