I've set up EFA to handle both incoming and outgoing and it all works nicely, I have one issue, and it may not even be an issue but I'll ask the question. My mail server is set to not write a dkim signature into the email, so it's sent without said sig onto EFA. When it arrives at the destination ( another of my accounts ) and when I test it using something like Ondmarc it has two dkim signatures that have been added, is this normal?
Sorted. It appears I had changed postfix/main.cf and commented out the wrong lines!
Only took me four hours to work that out.. impressive ( not! ).
[SOLVED] duplicate dkim
Re: [SOLVED] duplicate dkim
hi
how you solved double dkim ?
In my case i had a duplicate DKIM bec2ause it sign also when I receive from my internal mailserver
sulution is to put only localhost into internal hosts so it doennt sign when it arrives from internal mailserver
vi /etc/opendkim/TrustedHosts
127.0.0.1
::1
127.0.0.1
::1
