Hello
I have an EFAv3 server that suffered a crash due to power failure. Since then, I can longer mount the database. I have had limited success with database recovery mode, but not enough to export tables.
I would like to keep all my existing configurations - accepted domains, user accounts etc. but create a new empty SQL database. Loosing the history is not an issue for this system.
Is there a way to do this easily?
Matthew
						New Empty Database v3
Re: New Empty Database v3
wouldn't this be a good time to upgrade to v4?
if the database has been corrupted, beyond saving the efa configuration files, there is probably not an easy way since you mention user accounts.
Most of the important information is in various configuration files in different places.
Maybe my notes on how I upgraded from v3 to v4 will help you:
viewtopic.php?t=4325
