How to block countries
wind
Post by wind »
how to block country using GeoIP via iptables? i want to block some country specially China.
thanks,
Re: How to block countries
Have you tried searching the forums to see if anyone has had this question before?
Using this with google as my search parameters
"site:forum.efa-project.org block by country"
I found the following link that my be closest to what you want
viewtopic.php?t=1556
The RelayCountry module is already enabled. You just need to make sure your GeoIP database is up to date.
