Greylisting Whitelist
jamerson
Post by jamerson »
Dear All,
Lately been having issues with Grey listing, when customers email us from Office 365 takes ages untill its arrives.
So we decieded to start using Grey listing white listing.
let start
Step 1.
let create a file called clients_fqdn_whitelist.local on the sqlgrey listing
/etc/sqlgrey/clients_fqdn_whitelist.local
Step 2
let add the domains that will not be added to the sqlgrey listing scan
Domain.com
domain.net
jamesbond.com
Step 3
run sudo update_sqlgrey_config after add the domains to the list
Step 4
this is very important step to get the sql database check the domains. you have to restart the sqlgrey
sudo systemctl restart sqlgrey
to add domains in the future, just add the doam and follow steps 2 till 4.
if you have any questions let us know.
mattch
Re: Greylisting Whitelist
Post by mattch »
Im having same issue and find this. It appears whitelist protection.outlook.com instead of customer domains.
viewtopic.php?f=5&t=3685
