So far, so good. The vm was easy to import into VB and seems to be running OK with a few issues...but that's a subject for another post.
Hello EFA
scarpenter
Hello EFA
I have used ESVA for years on VMware, but found that the last time I went to get an update they had moved to Xenserver and their .xva file was impossible to convert to a working vmx. Then I changed to VirtualBox and trying to get the ESVA .xva converted to VirtualBox just ate up too much of my life. So here I am, hoping that this project will be better.
