I devepoped a piece of software, a sample script that create a list of most used 2nd level domains based on latest headers received
most used domains are checked for URIBL one time only and saved into a .cf that is used to skip URIBL check
so these domains most used are skipped and save tons of query , this can solve URIBL blocked problem !
This must be in crontab
# Uriskip, refresh list of excluded domains from uri check
01 02 * * 0 /etc/mail/spamassassin/uriskip.sh
And attached program into spamassassin dir
Uriskip, software
Uriskip, software
- uriskip.rar
- (2.52 KiB) Downloaded 583 times
Re: Uriskip, software
Ciao Nicola
Unfortunately the script ist not running on my efa box... i'll the the following output
any idea? thx for your help
./uriskip.sh: line 10:
: command not found
./uriskip.sh: line 42:
: command not found
./uriskip.sh: line 43:
: command not found
./uriskip.sh: line 47:
: command not found
./uriskip.sh: line 48:
: command not found
./uriskip.sh: line 52:
: command not found
./uriskip.sh: line 53:
: command not found
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
./uriskip.sh: line 58:
: command not found
./uriskip.sh: line 59:
: command not found
./uriskip.sh: line 63:
: command not found
./uriskip.sh: line 64:
: command not found
./uriskip.sh: line 70: syntax error near unexpected token `
./uriskip.sh: line 70: ` ((c++))
always happy for any hints and tipps!
| EFA 3.0.2.6
You ran script as is or you modified it ?
actually i did not modified anything expect the VURIFIXED Parameter
| EFA 3.0.2.6
Yes, but what you have at line ./uriskip.sh: line 10:
: command not found
: command not found
sorry Nicola
i shame on me...
i found the error. the uriskip.cf file was missing! everything works fine now!
thx a lot! buon estate
i shame on me...
| EFA 3.0.2.6
