[howto] Installing and using opendkim with EFA 4
Posted: 21 Jan 2019 03:12
				With Shawin been busy getting the V4 OPENDKIM up and configured. finally we got it configured
1 Download and install OpenDKIM
2 create a folder on the opendkim
3 browse to
4 run the below to generate the private and txt key
5 open the below with nano or vi
6 first line to check:
if it is just v change to sv
7 than look for word Socket inet= if it does exisit than its looks good
now find the below and out line them remove the # in front of each line .
save the file now
8 next, edit /etc/opendkim/KeyTable
so open the the file /etc/opendkim/KeyTable with nano or vi
save file
9 now edit /etc/opendkim/SigningTable
again open the file /etc/opendkim/SigningTable with nano or vi
add this at the end of the file
Save the file we are almost done
10 edit /etc/opendkim/TrustedHosts
so open the file /etc/opendkim/TrustedHosts with vi or nano
and add this to the end
mail.efa.org is your mx record
192.168.4.5/32 is your exchange ip / or internal mail server
11 edit /etc/postfix/main.cf
again open the file edit /etc/postfix/main.cf with nano or vi
go to very end of the file find the line starts with smtpd_milters = inet:127.0.0.1:8891 inet:127.0.0.1:33333 and empty everything below it. and past the below
save the file
restart the postfix
11 Adding DNS Records
Strangely enough, this is the part that gave me the most trouble as I wasn't putting in the text records correctly.
open the private key
assuming a value of
your DNS TXT record name is
your DNS record type is TXT
your DNS record value is
v
Don't keep the comment from the generated default.txt file. There is a limit on DNS records using UDP, and if the record is too big, the nameserver will have to make a TCP connection to get it all (slower)
i have a issue
so if you have this issue just run the next command to add the permission to your private key
now your opendkim is configured and sign outgoing emails.
if you have any questions let us knows.
yum install openssl-devel opendkimCode: Select all
mkdir -p /etc/opendkim/keys/efa.org/Code: Select all
cd /etc/opendkim/keys/efa.org/Code: Select all
opendkim-genkey -s efaCode: Select all
/etc/opendkim.conf6 first line to check:
Mode sv7 than look for word Socket inet= if it does exisit than its looks good
SendReports     yes
ReportAddress "efa.org Postmaster <postmaster@efa.org>"
SoftwareHeader  yes
 Canonicalization        relaxed/simple
 KeyTable        /etc/opendkim/KeyTable
SigningTable    refile:/etc/opendkim/SigningTable
xternalIgnoreList      refile:/etc/opendkim/TrustedHosts
InternalHosts   refile:/etc/opendkim/TrustedHostssave the file now
 add this line to the end:
 efa._domainkey.efa.org efa.org:efa:/etc/opendkim/keys/efa.org/efa.private9 now edit /etc/opendkim/SigningTable
*@efa.org efa._domainkey.efa.org
mail.efa.org
192.168.4.5/32192.168.4.5/32 is your exchange ip / or internal mail server
message_size_limit = 133169152
qmqpd_authorized_clients = 127.0.0.1 [::1]
enable_long_queue_ids = yes
non_smtpd_milters = inet:127.0.0.1:8891
milter_default_action = tempfail
milter_protocol = 2
error_notice_recipient = root@$myhostnamerestart the postfix
sudo systemctl restart postfix11 Adding DNS Records
cat /etc/opendkim/keys/<YOURDOMAIN>/default.txtCode: Select all
default._domainkey IN TXT "v=DKIM1; g=*; k=rsa; p=7k45u5i2T1AlEBeurUbdKh7Nypq4lLMXC2FHhezK33BuYR+3L7jxVj7FATylhwIDAQABMIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDHY7Zl+n3SUldTYRUEU1BErHkKN0Ya52gazp1R7FA7vN5RddPxW/sO9JVRLiWg6iAE4hxBp42YKfxOwEnxPADbBuiELKZ2ddxo2aDFAb9U/lp4" ; ----- DKIM default for example.comCode: Select all
default._domainkeyyour DNS record value is
v
=DKIM1; g=*; k=rsa; p=7k45u5i2T1AlEBeurUbdKh7Nypq4lLMXC2FHhezK33BuYR+3L7jxVj7FATylhwIDAQABMIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDHY7Zl+n3SUldTYRUEU1BErHkKN0Ya52gazp1R7FA7vN5RddPxW/sO9JVRLiWg6iAE4hxBp42YKfxOwEnxPADbBuiELKZ2ddxo2aDFAb9U/lp4i have a issue
Jan 29 00:55:05 relay opendkim[6300]: can't load key from /etc/opendkim/keys/domain.com/domain.private: Permission deniedCode: Select all
sudo chown opendkim /etc/opendkim/keys/domain.com/domain.privatenow your opendkim is configured and sign outgoing emails.
