[howto] Installing and using opendkim with EFA 4
jamerson
Post by jamerson » 21 Jan 2019 03:12
With Shawin been busy getting the V4 OPENDKIM up and configured. finally we got it configured
1 Download and install OpenDKIM
yum install openssl-devel opendkim
2 create a folder on the opendkim
mkdir -p /etc/opendkim/keys/efa.org/
3 browse to
cd /etc/opendkim/keys/efa.org/
4 run the below to generate the private and txt key
opendkim-genkey -s efa
5 open the below with nano or vi
/etc/opendkim.conf
6 first line to check:
Mode sv
if it is just v change to sv
7 than look for word Socket inet= if it does exisit than its looks good
now find the below and out line them remove the # in front of each line .
SendReports     yes
ReportAddress "efa.org Postmaster <postmaster@efa.org>"
SoftwareHeader  yes
 Canonicalization        relaxed/simple
 KeyTable        /etc/opendkim/KeyTable
SigningTable    refile:/etc/opendkim/SigningTable
xternalIgnoreList      refile:/etc/opendkim/TrustedHosts
InternalHosts   refile:/etc/opendkim/TrustedHosts
save the file now
8 next, edit /etc/opendkim/KeyTable
so open the the file /etc/opendkim/KeyTable with nano or vi
 add this line to the end:
 efa._domainkey.efa.org efa.org:efa:/etc/opendkim/keys/efa.org/efa.private
save file
9 now edit /etc/opendkim/SigningTable
again open the file /etc/opendkim/SigningTable with nano or vi
add this at the end of the file
*@efa.org efa._domainkey.efa.org
Save the file we are almost done :)
10 edit /etc/opendkim/TrustedHosts
so open the file /etc/opendkim/TrustedHosts with vi or nano
and add this to the end
mail.efa.org
192.168.4.5/32
mail.efa.org is your mx record
192.168.4.5/32 is your exchange ip / or internal mail server
11 edit /etc/postfix/main.cf
again open the file edit /etc/postfix/main.cf with nano or vi
go to very end of the file find the line starts with smtpd_milters = inet:127.0.0.1:8891 inet:127.0.0.1:33333 and empty everything below it. and past the below
message_size_limit = 133169152
qmqpd_authorized_clients = 127.0.0.1 [::1]
enable_long_queue_ids = yes
non_smtpd_milters = inet:127.0.0.1:8891
milter_default_action = tempfail
milter_protocol = 2
error_notice_recipient = root@$myhostname
save the file
restart the postfix
sudo systemctl restart postfix
11 Adding DNS Records
Strangely enough, this is the part that gave me the most trouble as I wasn't putting in the text records correctly.
open the private key
cat /etc/opendkim/keys/<YOURDOMAIN>/default.txt
assuming a value of
default._domainkey IN TXT "v=DKIM1; g=*; k=rsa; p=7k45u5i2T1AlEBeurUbdKh7Nypq4lLMXC2FHhezK33BuYR+3L7jxVj7FATylhwIDAQABMIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDHY7Zl+n3SUldTYRUEU1BErHkKN0Ya52gazp1R7FA7vN5RddPxW/sO9JVRLiWg6iAE4hxBp42YKfxOwEnxPADbBuiELKZ2ddxo2aDFAb9U/lp4" ; ----- DKIM default for example.com
your DNS TXT record name is
default._domainkey
your DNS record type is TXT
your DNS record value is
v
Don't keep the comment from the generated default.txt file. There is a limit on DNS records using UDP, and if the record is too big, the nameserver will have to make a TCP connection to get it all (slower)
i have a issue
Jan 29 00:55:05 relay opendkim[6300]: can't load key from /etc/opendkim/keys/domain.com/domain.private: Permission denied
so if you have this issue just run the next command to add the permission to your private key
sudo chown opendkim /etc/opendkim/keys/domain.com/domain.private
now your opendkim is configured and sign outgoing emails.
if you have any questions let us knows.
Alleyviper
Re: [howto] Installing and using opendkim with EFA 4
Post by Alleyviper » 21 Jan 2019 06:30
Hi Jamerson,
Deployed opendkim with your instructions, but have just one thing to say
sudo cd /etc/opendkim/keys/domain.tld/
[user@mx2 ~]$ ls
domain.private  domain.txt
Is this ok?
Best regards
jamerson
Post by jamerson » 21 Jan 2019 13:57
Alleyviper wrote:
21 Jan 2019 06:30
Hi Jamerson,
[user@mx2 ~]$ ls
Is this ok?
Best regards
Yes this ok.
You should have two files domain.txt and domain.private.
Domain.txt is the info you will need for your dns txt record.
Post by henk » 02 Mar 2019 10:15
Hi Jamerson,
Did you manage to solve the Selinux issues as mentioned in viewtopic.php?t=3403?
Alleyviper
Post by Alleyviper » 18 Mar 2019 08:28
For Outbound Dkim signing check my solution on EFA 3.0.2.6
https://forum.efa-project.org/viewtop ... 5#p13835
