Hello
I am new on this group + efa server.
I am making some tests with EFA + Exchange 2016
I have some test emails getting :
High Score Spam: Y Action(s): store
And keeps it on quarantine
WHen I release it to mailbox server.. What i see on the header is..
X-Spam-Status: No
X-Onur-MailScanner-EFA-Watermark: 1542727336.59845@hC99JnCNxZFwZAHIYtsp8g
X-Onur-MailScanner-EFA-From: abc@xxxx.net
X-Onur-MailScanner-EFA: Found to be clean
X-Onur-MailScanner-EFA-ID: 5619F20066.A7A13
is it normal?
DOes it automatically changes the spam status to no on efa side when released?
Or does exchange makes a modification to header?
Regards
XSpam = Yes or No??
Re: XSpam = Yes or No??
900 viewers and no reply.. Very helpful forum
ANyway.. solved..
JunkMail settings were disabled on exchange..
Enabled..and added a rule to mark the mails with scp 9 if there is XSpam=yes tag on the header..
ANyway.. solved..
