Clamd update kills my EFA
jamerson
Post by jamerson »
Hi guys,
after the last update of the antivirus CLAMD my EFA keeps detecting everything as spam.
Clamd::ERROR:: COULD NOT CONNECT TO CLAMD, RECOMMEND RESTARTING DAEMON :: .
Jul 13 10:20:42 filter MailScanner[3045]: Virus Scanning: Clamd found 1 infections
Jul 13 10:20:42 filter MailScanner[3045]: Virus Scanning: No virus scanners worked, so message batch was abandoned and retried!
alle emails are infected according to the CLAM. to release the emails we had to reboot the EFA otherwise they are not deleverd.
when i log to the web gui i can see the emails there but to release them is only reboot the EFA.
E-mail Preambulen
Subject: Cron <clam@filter> [ -x /usr/bin/clamav-unofficial-sigs.sh ] && /bin/bash /usr/bin/clamav-unofficial-sigs.sh > /dev/null
Content-Type: text/plain; charset=UTF-8
Auto-Submitted: auto-generated
X-Cron-Env: <LANG=en_US.UTF-8>
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/var/lib/clamav>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=clam>
X-Cron-Env: <USER=clam>
[root@filter admin]# service clamd start
LibClamAV Warning: cli_loadyara: failed to parse or load 7 yara rules from file /var/lib/clamav/antidebug_antivm.yar, successfully loaded 92 rules.
LibClamAV Warning: Detected duplicate databases /var/lib/clamav/main.cvd and /var/lib/clamav/main.cld, please manually remove one of them
The Solutions is :
the solution is
 /etc/clamav-unofficial-sigs/master.conf
 yararulesproject_enabled="no"
 enable_yararules="no"
delete *.yar and *.yara from /var/lib/clamav/
command to delete and restart the service
sudo rm /var/lib/clamav/*yar
sudo rm /var/lib/clamav/*yara
sudo service clamd start
jamerson
Re: Clamd update kills my EFA
Post by jamerson »
See above the solution.
if you have any questions let me know
bikertrash
Post by bikertrash »
Thank you for this... looks like it did the trick for me as well.
rvwaveren
Post by rvwaveren »
Just replying to say this fixed it for me as well, thanks!
jogomes
Post by jogomes »
Hi to all,
Updating to Clamav 0.100.1 did caused the issue.
Solution presented solved the issue.
JG
g-force-j
Post by g-force-j »
Hi all,
Updating to 0.101.2 and EFA-3.0.2.6 caused this for me.
The solution still works!
larsborris
Post by larsborris »
Hello!
Just started with eFa today.
I downloaded the newest hyper-v template, updated it and it broke.
However, this solved my problem.
Gogo
Post by Gogo »
Great solution to this problem.
Thanks all
andyhud
Post by andyhud »
+1
Great solution - works well
djshaunvt
Post by djshaunvt »
Thanks for your post.
I am a bit of a Centos noob.
I have edited the options in master.conf but I'm stuck by the the line of code that says:
Are you supposed to run that in the Centos Shell ?
djshaunvt
Post by djshaunvt »
Thanks that was it..
Appreciated :D
djshaunvt
Post by djshaunvt »
Only the powers that be now know how I'm going to pull this one off :idea:
viewtopic.php?t=3311
djshaunvt
Post by djshaunvt »
Thanks,
Managed to pull it off by connecting to the Centos EFA server Via Winscp and had to modify permissions to the /var/www/html/mailscanner/temp directory as it kept on giving me permission errors and wouldnt copy the files.
I used the following (I hope not doing anything that will affect security of the box :) )
sudo chmod 777 /var/www/html/mailscanner/temp
Thanks again
iandarke
Post by iandarke »
Thanks -- I had the same issue and this resolved it for me.
barbours
Post by barbours »
Solution worked for me as well. Thanks all.
