extra packages installed?
bbrendon
Post by bbrendon »
why is exim4 AND postfix installed? is that supposed to be happening? it looks like exim can be removed, no?
also, you can remove popularity-contest from the next release ;)
darky83
Site Admin
Re: extra packages installed?
Post by darky83 »
Exim is not installed (it was removed by the Postfix installation during build)
it however keeps the config files during postfix installation.
dpkg -l | grep exim
rc  exim4                              4.72-6+squeeze2              metapackage to ease Exim MTA (v4) installation
rc  exim4-base                         4.72-6+squeeze2              support files for all Exim MTA (v4) packages
rc  exim4-config                       4.72-6+squeeze2              configuration for the Exim MTA (v4)
rc  exim4-daemon-light                 4.72-6+squeeze2              lightweight Exim MTA (v4) daemon
(status RC) I will remove these in the next update, good point by the way :)
Will also remove popularity-contest.
bbrendon
Post by bbrendon »
Whoops. My mistake. I'm so used to purging packages and I forgot you can "remove" packages. :)
