refused to talk to me: 554 Transaction failed
samrein
Post by samrein »
i hope anyone can help me. We have ESVA installed, an now i am installing EVA as new version. It works, but some mails hang in the queue with the message "refused to talk to me: 554 Transaction failed". I have found at google that the other mailserver the mail reject. Maybe bad response or high spam score. But I do not think so. I have checked both config from each server. Where can i search for this mistake? Sorry for my bad english.
Regards
Stefan
postconf -n
smtpd_delay_reject = yes
smtpd_discard_ehlo_keyword_address_maps =
smtpd_discard_ehlo_keywords =
smtpd_dns_reply_filter =
smtpd_end_of_data_restrictions =
smtpd_enforce_tls = no
smtpd_error_sleep_time = 1s
smtpd_etrn_restrictions =
smtpd_expansion_filter = \t\40!"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_`abcdefghijklmnopqrstuvwxyz{|}~
smtpd_forbidden_commands = CONNECT GET POST
smtpd_hard_error_limit = ${stress?{1}:{20}}
smtpd_helo_required = yes
smtpd_helo_restrictions = check_helo_access hash:/etc/postfix/helo_access, reject_invalid_hostname
smtpd_history_flush_threshold = 100
smtpd_junk_command_limit = ${stress?{1}:{100}}
smtpd_log_access_permit_actions =
smtpd_milters =
smtpd_noop_commands =
smtpd_null_access_lookup_key = <>
smtpd_peername_lookup = yes
smtpd_per_record_deadline = ${stress?{yes}:{no}}
smtpd_policy_service_default_action = 451 4.3.5 Server configuration problem
smtpd_policy_service_max_idle = 300s
smtpd_policy_service_max_ttl = 1000s
smtpd_policy_service_policy_context =
smtpd_policy_service_request_limit = 0
smtpd_policy_service_retry_delay = 1s
smtpd_policy_service_timeout = 100s
smtpd_policy_service_try_limit = 2
smtpd_proxy_ehlo = $myhostname
smtpd_proxy_filter =
smtpd_proxy_options =
smtpd_proxy_timeout = 100s
smtpd_recipient_limit = 1000
smtpd_recipient_overshoot_limit = 1000
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, check_policy_service inet:127.0.0.1:2501
smtpd_reject_footer =
smtpd_reject_unlisted_recipient = yes
smtpd_reject_unlisted_sender = no
smtpd_relay_restrictions = permit_mynetworks, permit_sasl_authenticated, defer_unauth_destination
smtpd_restriction_classes =
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = no
smtpd_sasl_exceptions_networks =
smtpd_sasl_local_domain =
smtpd_sasl_path = smtpd
smtpd_sasl_security_options = noanonymous
smtpd_sasl_service = smtp
smtpd_sasl_tls_security_options = $smtpd_sasl_security_options
smtpd_sasl_type = cyrus
smtpd_sender_login_maps =
smtpd_service_name = smtpd
smtpd_soft_error_limit = 10
smtpd_starttls_timeout = ${stress?{10}:{300}}s
smtpd_timeout = ${stress?{10}:{300}}s
smtpd_tls_CAfile = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_CApath =
smtpd_tls_always_issue_session_ids = yes
smtpd_tls_ask_ccert = no
smtpd_tls_auth_only = no
smtpd_tls_ccert_verifydepth = 9
smtpd_tls_cert_file = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_ciphers = medium
smtpd_tls_dcert_file =
smtpd_tls_dh1024_param_file = /etc/postfix/ssl/dhparam.pem
smtpd_tls_dh512_param_file =
smtpd_tls_dkey_file = $smtpd_tls_dcert_file
smtpd_tls_eccert_file =
smtpd_tls_eckey_file = $smtpd_tls_eccert_file
smtpd_tls_eecdh_grade = strong
smtpd_tls_exclude_ciphers =
smtpd_tls_fingerprint_digest = md5
smtpd_tls_key_file = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_loglevel = 1
smtpd_tls_mandatory_ciphers = medium
smtpd_tls_mandatory_exclude_ciphers =
smtpd_tls_received_header = yes
smtpd_tls_req_ccert = no
smtpd_tls_session_cache_database = btree:/var/lib/postfix/smtpd_tls_session_cache
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_wrappermode = no
smtpd_upstream_proxy_protocol =
smtpd_upstream_proxy_timeout = 5s
smtpd_use_tls = yes
smtputf8_autodetect_classes = sendmail, verify
smtputf8_enable = no
soft_bounce = no
stale_lock_time = 500s
stress =
strict_7bit_headers = no
strict_8bitmime = no
strict_8bitmime_body = no
strict_mailbox_ownership = yes
strict_mime_encoding_domain = no
strict_rfc821_envelopes = no
strict_smtputf8 = no
sun_mailtool_compatibility = no
swap_bangpath = yes
syslog_facility = mail
syslog_name = ${multi_instance_name?{$multi_instance_name}:{postfix}}
tcp_windowsize = 0
tls_append_default_CA = no
tls_daemon_random_bytes = 32
tls_dane_digest_agility = on
tls_dane_digests = sha512 sha256
tls_dane_trust_anchor_digest_enable = yes
tls_disable_workarounds =
tls_eecdh_strong_curve = prime256v1
tls_eecdh_ultra_curve = secp384r1
tls_export_cipherlist = aNULL:-aNULL:HIGH:MEDIUM:LOW:EXPORT:+RC4:@STRENGTH
tls_high_cipherlist = aNULL:-aNULL:HIGH:@STRENGTH
tls_legacy_public_key_fingerprints = no
tls_low_cipherlist = aNULL:-aNULL:HIGH:MEDIUM:LOW:+RC4:@STRENGTH
tls_medium_cipherlist = ECDSA+AESGCM:ECDH+AESGCM:DH+AESGCM:ECDSA+AES:ECDH+AES:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
tls_null_cipherlist = eNULL:!aNULL
tls_preempt_cipherlist = yes
tls_random_bytes = 32
tls_random_exchange_name = ${data_directory}/prng_exch
tls_random_prng_update_period = 3600s
tls_random_reseed_period = 3600s
tls_random_source = dev:/dev/urandom
tls_session_ticket_cipher = aes-256-cbc
tls_ssl_options =
tls_wildcard_matches_multiple_labels = yes
tlsmgr_service_name = tlsmgr
tlsproxy_enforce_tls = $smtpd_enforce_tls
tlsproxy_service_name = tlsproxy
tlsproxy_tls_CAfile = $smtpd_tls_CAfile
tlsproxy_tls_CApath = $smtpd_tls_CApath
tlsproxy_tls_always_issue_session_ids = $smtpd_tls_always_issue_session_ids
tlsproxy_tls_ask_ccert = $smtpd_tls_ask_ccert
tlsproxy_tls_ccert_verifydepth = $smtpd_tls_ccert_verifydepth
tlsproxy_tls_cert_file = $smtpd_tls_cert_file
tlsproxy_tls_ciphers = $smtpd_tls_ciphers
tlsproxy_tls_dcert_file = $smtpd_tls_dcert_file
tlsproxy_tls_dh1024_param_file = $smtpd_tls_dh1024_param_file
tlsproxy_tls_dh512_param_file = $smtpd_tls_dh512_param_file
tlsproxy_tls_dkey_file = $smtpd_tls_dkey_file
tlsproxy_tls_eccert_file = $smtpd_tls_eccert_file
tlsproxy_tls_eckey_file = $smtpd_tls_eckey_file
tlsproxy_tls_eecdh_grade = $smtpd_tls_eecdh_grade
tlsproxy_tls_exclude_ciphers = $smtpd_tls_exclude_ciphers
tlsproxy_tls_fingerprint_digest = $smtpd_tls_fingerprint_digest
tlsproxy_tls_key_file = $smtpd_tls_key_file
tlsproxy_tls_loglevel = $smtpd_tls_loglevel
tlsproxy_tls_mandatory_ciphers = $smtpd_tls_mandatory_ciphers
tlsproxy_tls_mandatory_exclude_ciphers = $smtpd_tls_mandatory_exclude_ciphers
tlsproxy_tls_mandatory_protocols = $smtpd_tls_mandatory_protocols
tlsproxy_tls_protocols = $smtpd_tls_protocols
tlsproxy_tls_req_ccert = $smtpd_tls_req_ccert
tlsproxy_tls_security_level = $smtpd_tls_security_level
tlsproxy_use_tls = $smtpd_use_tls
tlsproxy_watchdog_timeout = 10s
trace_service_name = trace
transport_maps = hash:/etc/postfix/transport
transport_retry_time = 60s
trigger_timeout = 10s
undisclosed_recipients_header =
unknown_address_reject_code = 450
unknown_address_tempfail_action = $reject_tempfail_action
unknown_client_reject_code = 450
unknown_helo_hostname_tempfail_action = $reject_tempfail_action
unknown_hostname_reject_code = 450
unknown_local_recipient_reject_code = 550
unknown_relay_recipient_reject_code = 550
unknown_virtual_alias_reject_code = 550
unknown_virtual_mailbox_reject_code = 550
unverified_recipient_defer_code = 450
unverified_recipient_reject_code = 450
unverified_recipient_reject_reason =
unverified_recipient_tempfail_action = $reject_tempfail_action
unverified_sender_defer_code = 450
unverified_sender_reject_code = 450
unverified_sender_reject_reason =
unverified_sender_tempfail_action = $reject_tempfail_action
verp_delimiter_filter = -=+
virtual_alias_address_length_limit = 1000
virtual_alias_domains = $virtual_alias_maps
virtual_alias_expansion_limit = 1000
virtual_alias_maps = hash:/etc/postfix/virtual
virtual_alias_recursion_limit = 1000
virtual_delivery_slot_cost = $default_delivery_slot_cost
virtual_delivery_slot_discount = $default_delivery_slot_discount
virtual_delivery_slot_loan = $default_delivery_slot_loan
virtual_delivery_status_filter = $default_delivery_status_filter
virtual_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
virtual_destination_concurrency_limit = $default_destination_concurrency_limit
virtual_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
virtual_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
virtual_destination_rate_delay = $default_destination_rate_delay
virtual_destination_recipient_limit = $default_destination_recipient_limit
virtual_extra_recipient_limit = $default_extra_recipient_limit
virtual_gid_maps =
virtual_initial_destination_concurrency = $initial_destination_concurrency
virtual_mailbox_base =
virtual_mailbox_domains = $virtual_mailbox_maps
virtual_mailbox_limit = 51200000
virtual_mailbox_lock = fcntl, dotlock
virtual_mailbox_maps =
virtual_minimum_delivery_slots = $default_minimum_delivery_slots
virtual_minimum_uid = 100
virtual_recipient_limit = $default_recipient_limit
virtual_recipient_refill_delay = $default_recipient_refill_delay
virtual_recipient_refill_limit = $default_recipient_refill_limit
virtual_transport = virtual
virtual_transport_rate_delay = $default_transport_rate_delay
virtual_uid_maps =
Re: refused to talk to me: 554 Transaction failed
You have a rather complex posfix config, imo. I would suggest starting out with a more vanilla configuration and working forward with customizations while testing postfix along the way.
samrein
Post by samrein »
i have found the error. My Firewall NAT doesnt work correct, so my mailserver has a wrong outgoing ip. Some Mailserver check PTR records, and that was the mistake. After i configure the right NAT that works fine.
Thanks for the update.
