yeah, I know, but I thought I'd give it a try
I have reduced the mem back down to 256MB
; Maximum amount of memory a script may consume (128MB)
; http://www.php.net/manual/en/ini.core.php#ini.memory-limit
memory_limit = 256M
I have also restarted httpd, I even rebooted the VM (running on KVM)
as well as mailscanner
everything in the update logs is clean, no errors besides the usual culprits
*** ERROR/WARNING SUMMARY ***
Table Index: MySQL version unsupported for index `subject_idx` on table `maillog`, upgrade to version >= 50604 (you have version 50505)
conf.php: obsolete configuration entry "TTF_DIR" still present
conf.php: optional configuration entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: optional configuration entry "VIRUS_REGEX" is missing, needed in distributed setup
conf.php: optional configuration entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: optional configuration entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: optional configuration entry "SENDMAIL_QUEUE_IN" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "SENDMAIL_QUEUE_OUT" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "USER_SELECTABLE_LANG" is missing, comma separated list of codes for languages the users can use eg. "de,en,fr,it,nl,pt_br"
conf.php: optional configuration entry "MAILWATCH_SMTP_HOSTNAME" is missing, needed only if you use a remote SMTP server to send MailWatch emails
conf.php: optional configuration entry "SESSION_TIMEOUT" is missing, needed if you want to override the default session timeout
conf.php: optional configuration entry "ALLOW_NO_USER_DOMAIN" is missing, allow usernames not in mail format for domain admins and regular users
conf.php: optional configuration entry "ENABLE_SUPER_DOMAIN_ADMINS" is missing, allows domain admins to change domain admins from the same domain
(wanted to post it, but it's too long
I have also upped the VMs memory from 4GB to 6GB without any result.....
total used free shared buffers cached
Mem: 5992980 2104048 3888932 4176 31148 764884
-/+ buffers/cache: 1308016 4684964
Swap: 0 0 0
I just hope that I am not just being a "numpty"
