I noticed that messages blocked as bad content are not displayed in the quarantined report, so they are not seen.
I belive, looking in the forum, which they should normally be there.
Can someone tell me how to make them appear in report?
Thank you
						bad content messages in quarantined report
Re: bad content messages in quarantined report
Hi sbergami,
take a look at
There are some options available
Just be carefull, releasing mail with bad content can be a bummer
							take a look at
/var/www/html/mailscanner/conf.phpCode: Select all
// Hide High Spam and high mcp from regular users.
// Prevent regular users from seeing high spam and high mcp.
define('HIDE_HIGH_SPAM', false);
// Hide Non Spam from quarantine reports
define('HIDE_NON_SPAM', true);
Hi henk, thank you
users can only see blocked emails, I will release them after checking if they are good.
