I have problem witch release message - MailWatch for MailScanner v1.2.7-dev running on EFA-3.0.2.6.
Error : Release: error code 75 returned from Sendmail: sendmail: fatal: xxxx@xxxx.coml(48): Recipient addresses must be specified on the command line or via the -t option postdrop: warning: stdin: unexpected EOF in data, record type 78 length 76 postdrop: fatal: uid=48: malformed input
How fix the problem?
Release Message
Re: Release Message
FIX IT
I add define('MAILWATCH_FROM_ADDR')
Thx!
M.
Thx!
M.
Re: Release Message
Hi, I have same problem with the release function.
I get the same error message when i try to use it.
I read you can solve it.
Could you tell me where can I define the next line: ('MAILWATCH_FROM_ADDR')?
Best Wishes
M.
Best Wishes
M.
Re: Release Message
// Change with a fully qualified email address
define('MAILWATCH_FROM_ADDR', 'defined_user@xxxx.yyy');
P.S. You can use search in this forum
