Multiple destination server
Sander81
Post by Sander81 »
Dear all,
Is it possible to set up multiple destination server on transport setting for a domain?
I need to set something like:
Domain.com -> 1.1.1.1
Domain.com -> 1.1.1.2
So if the server 1.1.1.1 is down, mails are delivered to 1.1.1.2
Thank you
thewomble
Re: Multiple destination server
Post by thewomble »
example.com :[gateway.example.com]
where gateway.example.com would two A records 1.1.1.1 and 1.1.1.2 it would round rob, so send to both.
or use load balancer for sending to 1.1.1.1 and 1.1.1.2 if the first is not available, do not think this logic is available in postfix.
What thewomble says. RRDNS or a single ip served by a load balancer.
If you’re really paranoid, you can have multiple, load balanced ips from multiple load balancers, but the I’ve never had a use case for this with email.
What exactly is the problem you are trying to solve/avoid?
