reboot
reboot
cat /etc/grub.conf[root@efa ~]# EFA-Update -update
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.5
Setting up Update Process
* EFA: dl.efa-project.org
* base: mirrors.163.com
* epel: mirror1.ku.ac.th
* extras: mirrors.163.com
* mariadb: nyc2.mirrors.digitalocean.com
* updates: mirrors.btte.net
No Packages marked for Update
Your system has an updated kernel, but you are not running
on the latest kernel. Please restart your system and run
EFA-Update after restart.
uname -adefault=1
timeout=15
splashimage=(hd0,0)/grub/splash.xpm.gz
#hiddenmenu
title CentOS (2.6.32-696.13.2.el6.x86_64.debug)
root (hd0,0)
kernel /vmlinuz-2.6.32-696.13.2.el6.x86_64.debug ro root=/dev/mapper/vg_00-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_LVM_LV=vg_00/lv_root rd_NO_MD KEYBOARDTYPE=pc KEYTABLE=us SYSFONT=latarcyrheb-sun16 crashkernel=auto rd_NO_DM vga=771 elevator=deadline
initrd /initramfs-2.6.32-696.13.2.el6.x86_64.debug.img
title CentOS (2.6.32-696.13.2.el6.x86_64)
root (hd0,0)
kernel /vmlinuz-2.6.32-696.13.2.el6.x86_64 ro root=/dev/mapper/vg_00-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_LVM_LV=vg_00/lv_root rd_NO_MD KEYBOARDTYPE=pc KEYTABLE=us SYSFONT=latarcyrheb-sun16 crashkernel=auto rd_NO_DM vga=771 elevator=deadline
initrd /initramfs-2.6.32-696.13.2.el6.x86_64.img
from /var/EFA/update/EFA-update-script:Linux efa.local 2.6.32-696.13.2.el6.x86_64 #1 SMP Thu Oct 5 21:22:16 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
CURRENTKERNEL="`uname -r`"
LATESTKERNEL="`grep -m 1 CentOS /boot/grub/menu.lst | sed 's/.*(//' | sed 's/)//'`"
Hmmm... Looks like the latest kernel check is a bit iffy when the grub menu list is not the same order as the update script expects. Solution? Change my grub boot order config file or exclude the debug kernels.[root@efa ~]# CURRENTKERNEL="`uname -r`"
[root@efa ~]# LATESTKERNEL="`grep -m 1 CentOS /boot/grub/menu.lst | sed 's/.*(//' | sed 's/)//'`"
[root@efa ~]# echo $CURRENTKERNEL
[root@efa ~]# echo $LATESTKERNEL
Let's exclude the debug kernels in the EFA-update-script
LATESTKERNEL="`grep CentOS /boot/grub/menu.lst | grep -v \.debug | head -1 | sed 's/.*(//' | sed 's/)//'`"
edit /etc/grub.conf and reorder
rerun EFA-Update -update
3.0.2.4 update complete*** ERROR/WARNING SUMMARY ***
Table Index: MySQL version unsupported for index `subject_idx` on table `maillog`, upgrade to version >= 50604 (you have version 50505)
conf.php: obsolete configuration entry "TTF_DIR" still present
conf.php: optional configuration entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: optional configuration entry "VIRUS_REGEX" is missing, needed in distributed setup
conf.php: optional configuration entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: optional configuration entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: optional configuration entry "SENDMAIL_QUEUE_IN" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "SENDMAIL_QUEUE_OUT" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "USER_SELECTABLE_LANG" is missing, comma separated list of codes for languages the users can use eg. "de,en,fr,it,nl,pt_br"
conf.php: optional configuration entry "MAILWATCH_SMTP_HOSTNAME" is missing, needed only if you use a remote SMTP server to send MailWatch emails
conf.php: optional configuration entry "SESSION_TIMEOUT" is missing, needed if you want to override the default session timeout
conf.php: optional configuration entry "ALLOW_NO_USER_DOMAIN" is missing, allow usernames not in mail format for domain admins and regular users
conf.php: optional configuration entry "ENABLE_SUPER_DOMAIN_ADMINS" is missing, allows domain admins to change domain admins from the same domain
3.0.2.5 update...
3.0.2.5 update complete, no other errors.*** ERROR/WARNING SUMMARY ***
rebooting...
everything appears to be running, mail delivery as normal, no obvious errors in the log files so far
