Haven't chacked on 3.0.2.4, but now I can't connect to webmin:
Chrome: ERR_SSL_VERSION_OR_CIPHER_MISMATCH
FF: An error occurred during a connection to server:10000. Cannot communicate securely with peer: no common encryption algorithm(s). Error code: SSL_ERROR_NO_CYPHER_OVERLAP
LetsEncrypt did the job for MailWatch, but not webmin.
miniserv.error:
[03/Oct/2017:12:06:20 +0300] miniserv.pl started
[03/Oct/2017:12:06:20 +0300] Using MD5 module Digest::MD5
[03/Oct/2017:12:06:20 +0300] Perl module Authen::PAM needed for PAM is not installed : Can't locate Authen/PAM.pm in @INC (@INC contains: /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at (eval 12) line 1.
BEGIN failed--compilation aborted at (eval 12) line 1.
3.0.2.5 Webmin Access
Re: 3.0.2.5 Webmin Access
What OS and browser are you using to connect to Webmin?
Managed to disable SSL. It looks I'll be fine. Possibly the the fault of my changes some time ago.
nano /etc/webmin/miniserv.conf
Change ssl=1 to ssl=0
/etc/init.d/webmin restart
/etc/init.d/httpd restart
Connect using http://server:10000
Webmin -> Webmin Configuration -> SSL Encryption
Update: after disabling SSL for webmin, managed to connect using http and fix certificate paths. Now back to working https.
Can you tell me what changes you made ? I'm struggling to find what i need to change to fix this ...
