Block Single IP or /24 Cidr without blocking the entire country
When you can't block unknown domains with Postfix for whatever reason, but you still want to mark it as spam without blocking the entire country.
(Since plugin Mail::SpamAssassin::Plugin::URILocalBL doesn't work.)
Example: Spam from US based Wowrack.com Net-range: 208.89.208.0 - 208.89.215.255
For some strange reason the spammer(s) are mainly in the 208.89.215.xxx net-range :drool:
Received: from epharab.loan (unknown [208.89.215.52])
Received: from wasptit.loan (unknown [208.89.215.47])
Received: from nyedumb.loan (unknown [208.89.215.48])
Received: from yikeest.loan (unknown [208.89.215.53])
Received: from hrhmar.loan (unknown [208.89.215.12])
Received: from poemesky.faith (unknown [208.89.210.118])
Option. Country block, works fine for countries. See the E.F.A. forum
countrybl.cf - modify Countries :idea:
ifplugin Mail::SpamAssassin::Plugin::RelayCountry
header   COUNTRY_RELAY_BH X-Relay-Countries =~ /BH/
describe COUNTRY_RELAY_BH Relayed through Bahrain
score    COUNTRY_RELAY_BH 3.5
header   COUNTRY_RELAY_CN X-Relay-Countries =~ /CN/
describe COUNTRY_RELAY_CN Relayed through China
score    COUNTRY_RELAY_CN 6.5
#etc etc
endif # Mail::SpamAssassin::Plugin::RelayCountry
Additional option, thanks to smyers119 Block IPs - modify IP's :idea:
blockip.cf
header CLASSMATE_NET Received =~ /208\.84\.4[0-7]\.\d{1,3}/
describe CLASSMATE_NET Spam Mail from 208.84.40.0/21
score CLASSMATE_NET 9.0
# or just a /24 range whatever suits your situation
header SPAMMING_IP Received =~ /208\.89\.215\.\d{1,3}/
describe SPAMMING_IP Spam Mail from 208.89.215.0/24
score SPAMMING_IP 6.0
This catches every ip from 208.84.40.0 to 208.84.47.255 and 208.89.215.0 to 208.89.215.255
Just put these 2 files in /etc/mail/spamassassin and restart MailScanner. Use MailScanner --lint to check! :!:
To get the descriptions visible: Reload rule_descriptions thru the Gui.
Re: Block Single IP or /24 Cidr without blocking the entire country
:clap: :dance: :violin: :text-bravo:
Odon Garma
Post by Odon Garma »
plugin must be enabled in init.pre?!
Yes, for the relay country: in
/etc/mail/spamassassin/init.pre
# RelayCountry - add metadata for Bayes learning, marking the countries
# a message was relayed through
# Note: This requires the Geo::IP Perl module
loadplugin Mail::SpamAssassin::Plugin::RelayCountry
# URIDNSBL - look up URLs found in the message against several DNS
# blocklists.
loadplugin Mail::SpamAssassin::Plugin::URIDNSBL
# Hashcash - perform hashcash verification.
loadplugin Mail::SpamAssassin::Plugin::Hashcash
# SPF - perform SPF verification.
loadplugin Mail::SpamAssassin::Plugin::SPF
To check dependency for installed modules (Geo::IP) : Gui-> Tools and Links-> SpamAssasin Lint (Test)
or exec
spamassassin --lint --debug
You should see something like this.
module installed: Digest::SHA1, version 2.12 		0.00014
module installed: HTML::Parser, version 3.64 		0.00012
module installed: Net::DNS, version 0.65 		0.00011
module installed: NetAddr::IP, version 4.078 		0.00011
module installed: Time::HiRes, version 1.9721 		0.00014
module installed: Archive::Tar, version 1.58 		0.00011
module installed: IO::Zlib, version 1.09 		0.00011
module installed: Digest::SHA1, version 2.12 		0.00012
module installed: MIME::Base64, version 3.08 		0.00011
module installed: DB_File, version 1.835 		0.00011
module installed: Net::SMTP, version 3.08 		0.00011
module installed: Mail::SPF, version v2.009 		0.00011
module installed: Geo::IP, version 1.45 		0.00011
module installed: Net::CIDR::Lite, version 0.21 	0.00014
module installed: Razor2::Client::Agent, version 2.84 	0.00012
module installed: IO::Socket::IP, version 0.37 		0.00011
module installed: IO::Socket::INET6, version 2.72 	0.00011
module installed: IO::Socket::SSL, version 1.31 	0.00011
module installed: Compress::Zlib, version 2.021 	0.00013
module installed: Mail::DKIM, version 0.37 		0.00011
module installed: DBI, version 1.609 			0.00011
module installed: Getopt::Long, version 2.38 		0.00013
module installed: LWP::UserAgent, version 5.833 	0.00013
module installed: HTTP::Date, version 5.831 		0.00011
module installed: Encode::Detect::Detector, version 1.01 	0.00011
module installed: Net::Patricia, version 1.22 		0.00011
module installed: Net::DNS::Nameserver, version 749
