After Update from EFA-3.0.1.8 to EFA-3.0.2.3 - Date/Time in Mailwatch from all Mails is the same
MatthiasG
Post by MatthiasG »
since the Update from EFA-3.0.1.8 to EFA-3.0.2.3 all Mails have the same Time/Date.
Thank you
Matthias
TheGr8Wonder
Re: After Update from EFA-3.0.1.8 to EFA-3.0.2.3 - Date/Time in Mailwatch from all Mails is the same
Post by TheGr8Wonder »
At what time did you perform your upgrade? Is there a device that queues messages going to EFA, when EFA is offline?
This was a bug recently caught in the MailWatch development branch. There's an unwanted update timestamp rule on the table that has been removed in the latest development.
That's weird. How come no one else is being bitten by this one?
jase72
Post by jase72 »
Running the update as per shawn's suggestion in viewtopic.php?p=8683#p8683 seemed to fix it for me.
However I did get the following warnings, which was the same as the initial EFA-Update summary (except EFA-Upgrade stopped a the "SESSION_NAME" line);
*** ERROR/WARNING SUMMARY ***
Table Index: MySQL version unsupported for index `subject_idx` on table `maillog`, upgrade to version >= 50604 (you have version 50505)
conf.php: optional configuration entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: optional configuration entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: optional configuration entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: optional configuration entry "USER_SELECTABLE_LANG" is missing, comma separated list of codes for languages the users can use eg. "de,en,fr,it,nl,pt_br"
conf.php: optional configuration entry "MAILWATCH_SMTP_HOSTNAME" is missing, needed only if you use a remote SMTP server to send MailWatch emails
conf.php: optional configuration entry "SESSION_TIMEOUT" is missing, needed if you want to override the default session timeout
Edited to add -- The MySQL error can be ignored, as per viewtopic.php?p=8712#p8712. Rest are optional, so presumably safe to ignore as well.
