3.0.1.9 - upgrade
bostjanc
3.0.1.9 - upgrade
Post by bostjanc »
No bugs to report, just would like to say the upgrade went smoothly and very good job done by "shawniverson".
Thumbs up
Re: 3.0.1.9 - upgrade
There's a few small issues, mainly some mod_security exceptions needed that will be helpful, and a few fixes in MailWatch :D
We are going to release a 3.0.2.0 maintenance release soon to address those issues :)
mtfs
Post by mtfs »
After the upgrade, we're having a problem looking at the contents of email that have attachments. This is only from within Mailwatch. The email itself arrives as normal, but MailWatch only displays a series of "Part 11 not found" and "Part 12 not found" messages. It is affecting mail that was sent before the upgrade, so would seem to be MailWatch specific.
Other than that, no apparent problems.
Edit: All messages appear as normal when looking in /var/spool/MailScanner/quarantine/ via SSH, but a high percentage of the messages can't be displayed from within MailWatch. I haven't yet found an exact pattern. Has anyone else had this issue?
Edit #2: Nevermind. Found the thread on the PHP fix in the Bugs section. All better now. Thanks.
Daniel Beardsmore
Post by Daniel Beardsmore »
Just in case this means anything to anyone:
Updating database schema:
- Adding missing index `subject_idx` on table `maillog`.............. WARNING
*** ERROR/WARNING SUMMARY ***
Table Index: MySQL version unsupported for index `subject_idx` on table `maillog`, upgrade to version >= 50604 (you have version 50505)
It appears not to be serious.
It is not, it is a false warning. MariaDB 10.1 is > Mysql 50604.
