add SMTPUTF8
bostjanc
add SMTPUTF8
Post by bostjanc »
Is there a way to add SMTPUTF8 (both: send and recieve) support to EFA SMTP server?
EmailSendService.SendMail(): mail not sent to 'ayça.ozdem@domain.com' [System.Net.Mail.SmtpException: The client or server is only configured for E-mail addresses with ASCII local-parts: ayça.ozdem@domain.com.
bostjanc
Re: add SMTPUTF8
Post by bostjanc »
Is it enough to enable?
smtputf8_enable = from no to yes ?
and reload postfix?
because I see it in the comments that "requires EAI support compiled in", what is that?
# SMTP UTF8 support (requires EAI support compiled in)
smtputf8_enable = no
Re: add SMTPUTF8
It may have been disabled in EFA for a reason.
More information about this setting here: http://www.postfix.org/SMTPUTF8_README.html
bostjanc
Re: add SMTPUTF8
Post by bostjanc »
Thanks for the reply.
I have already read that article before posting here.
There is where I have discovered what it needs to be changed in main.cf.
What would be the reason that EFA installation puts that option to disabled? Any particular?
Thanks, with best regards.
Re: add SMTPUTF8
EAI will not compile properly on CentOS 6x if I recall correctly. Postfix does not have EAI support compiled in for that reason.
bostjanc
Re: add SMTPUTF8
Post by bostjanc »
Thanks for the clarification!
