Disable outgoing RBL checks
largo
Post by largo »
Is there any way to disable outgoing RBL checks without whilisting the mailservers.
/Largo
Re: Disable outgoing RBL checks
RBL checks in SA, mailscanner, or postfix? I'm guessing SA...
MailScanner -- yes, with a ruleset, but this would disable all SA scanning rules for the source, not just RBL checks
SA -- probably requires some SA wizardry
postfix -- with an access list
# Do you want to find spam using the "SpamAssassin" package?
Use SpamAssassin = /path/to/some/saruleset
/path/to/some/saruleset (tab delimited)
To or From:      *      yes
largo
Post by largo »
Thanks for your answer. Will this disable OW to?
/Largo
Post by nicola.piazzi »
I think yes, for this reason i take enabled
You can put internal IP in mailscanner whitelist from mailscanner panel
This is the effect
Another useful thing is to use SHORTCIRCUIT
i put in email my example
