Hello everybody,
first of all: Thanks for the good work, i LOVE the project!!
I got EFA accepting external mails (As main mail-server for our webdomain) and delivering it to the internal exchange, I also configured it as relay for mails going outwards. But can I also use it as relay-host for an external Server? Can I add the external Server-IP to the "Outbound Mail Relay" menu and then it can relay mails? Or do I need to configure Authentication and if yes, has anyone done this before? I dont't want to make too deep changes in postfix.
Thansk a lot,
Jan
Using EFA as Relayhost internally AND externally?
Re: Using EFA as Relayhost internally AND externally?
That should work. You could set up authentication for added security, but that takes a little work.
