Updated to 3.2.2 no new mailwatch info being added
Posted: 12 May 2017 15:51
by c0mputerking
Hello all i have upgraded to 3.2.2 and my mailwatch does not seem to update anymore, I send and receive email through the system but my mailwatch webpage does not show any information since the upgrade to 3.2.2
Re: Updated to 3.2.2 no new mailwatch info being added
Posted: 13 May 2017 13:46
Are you seeing any errors when you restart MailScanner from the shell?
Posted: 14 May 2017 03:14
by c0mputerking
Hmm doesn't look like it?
etc/init.d/mailscanner start
MailScanner starting ...
MailScanner started with process id 25070
[root@efa-1 ~]#
Posted: 14 May 2017 10:23
by BliXem
Did you reboot your server?
Posted: 14 May 2017 21:32
by c0mputerking
Yes i rebooted my server a couple of time ... However things started working again last night not sure maybe when i reran the Database upgrade? Anyways thanks everyone for the Great help and the Great project! Glad this is solved now
Posted: 16 May 2017 08:43
Yeah, that makes sense. In the other post, you were missing the token field, that would definitely short circuit the logging to MailWatch.
