Updated to 3.2.2 no new mailwatch info being added
c0mputerking
Hello all i have upgraded to 3.2.2 and my mailwatch does not seem to update anymore, I send and receive email through the system but my mailwatch webpage does not show any information since the upgrade to 3.2.2
Re: Updated to 3.2.2 no new mailwatch info being added
Are you seeing any errors when you restart MailScanner from the shell?
c0mputerking
Hmm doesn't look like it?
etc/init.d/mailscanner start
MailScanner starting ...
MailScanner started with process id 25070
[root@efa-1 ~]#
[root@efa-1 ~]#
Did you reboot your server?
c0mputerking
Yes i rebooted my server a couple of time ... However things started working again last night not sure maybe when i reran the Database upgrade? Anyways thanks everyone for the Great help and the Great project! Glad this is solved now
Yeah, that makes sense. In the other post, you were missing the token field, that would definitely short circuit the logging to MailWatch.
