[Problem] Active Directory integration
Chriss
Post by Chriss »
Hey guys,
after running EFA (Version EFA-3.0.2.2) since some months i wanted to go a step further and authenticate the Website against my Server 2016 ADDS.
Followed the given guides at viewtopic.php?f=14&t=1484 and https://raw.githubusercontent.com/E-F-A ... LEASENOTES.
Here the modifications i made:
conf.php
// LDAP settings for authentication
define('USE_LDAP', true);
define('LDAP_SSL', false);
define('LDAP_HOST', '192.168.1.30');
define('LDAP_PORT', '389');
define('LDAP_DN', 'DC=my-real-domain,DC=eu');
define('LDAP_USER', 'cn=ldap,cn=users,dc=my-real-domain,dc=eu');
define('LDAP_PASS', 'Super-secure-Password');
define('LDAP_SITE', 'Default-First-Site-Name');
define('LDAP_FILTER', 'sAMAccountName=%s');
define('LDAP_USERNAME_FIELD', 'userprincipalname');
define('LDAP_MS_AD_COMPATIBILITY', true);
in functions.php
function ldap_authenticate($username, $password)
    $username = ldap_escape(strtolower($username), '', LDAP_ESCAPE_DN);
    if ($username !== '' && $password !== '') {
        ldap_set_option($ds, LDAP_OPT_REFERRALS, 0);			// as found in release notes
        ldap_set_option($ds, LDAP_OPT_PROTOCOL_VERSION, 3);	// as found in release notes
        $ds = ldap_connect(LDAP_HOST, LDAP_PORT) or die(__('ldpaauth103') . ' ' . LDAP_HOST);
Now the problem: i can't successfully login with my ADDS username (wrong username or password), the funny part of that is that i tcpdump'ed the communication between efa and my dc with the following result:
.30 = adds
.38 = efa
4	0.000470	192.168.1.38	192.168.1.30	LDAP	124	bindRequest(1) "cn=ldap,cn=users,dc=my-real-domain,dc=eu" simple
5	0.002222	192.168.1.30	192.168.1.38	LDAP	88	bindResponse(1) success
7	0.002339	192.168.1.38	192.168.1.30	LDAP	150	searchRequest(2) "DC=my-real-domain,DC=eu" wholeSubtree
17	0.014419	192.168.1.30	192.168.1.38	LDAP	880	searchResEntry(2) "CN=my.adlogin,OU=users,DC=my-real-domain,DC=eu"
18	0.015271	192.168.1.38	192.168.1.30	LDAP	124	bindRequest(3) "my.adlogin@my-real-domain.eu" simple
19	0.017125	192.168.1.30	192.168.1.38	LDAP	88	bindResponse(3) success
20	0.017615	192.168.1.38	192.168.1.30	LDAP	73	unbindRequest(4)
If you ask me it should work... do you have any idea how to go deeper in troubleshooting or maybe had the same problem and a solution for me?
Greetings
Chriss
Re: [Problem] Active Directory integration
These two lines should not be present since define('LDAP_MS_AD_COMPATIBILITY', true) takes care of this now. (although they shouldn't cause any problems, either)
Chriss
Post by Chriss »
Hey shawniverson,
removed the two lines and tested again: same phenomenon, wireshark trace says bindRespone success but webpage says username or password wrong. :-(
The bind is successful, so it is likely that the lookup itself after the bind is returning no matching results.
The problem is here...
This is combined with the following by default:
define('LDAP_BIND_PREFIX', 'cn=');
define('LDAP_BIND_SUFFIX', ',' . LDAP_DN);
Which doesn't make any sense, because the userPrincipalName in the cn field will surely fail.
Looking at the MailWatch code, it is clear that the LDAP_USERNAME_FIELD is not the username entered into the login interface, but rather the results returned by LDAP. Since the filter is sAMAccountName, it should the cn or sAMAccountName, in your case, not userPrincipalName
define('LDAP_USERNAME_FIELD', 'cn');
Now if only we had forum antispam like we have for mail.
Get to work on that please :D , I think this spammer is the same person and keeps creating new accounts, very annoying....
Does anyone have any recommendations on how we can debug this?
If I could see the requests sent, and the replies received, I'll be better able to figure out what is going wrong rather than making random changes and hoping it'll work.
smyers119
Post by smyers119 »
Are you able to manually do the lookup with "ldapsearch" and return a successful result? This works fine for me on 4.0.2. I am even using SSL.
Yes, I can. ldapsearch works fine. I can query and see everything I expect to see.
ldapsearch -x -h <server> -D <username> -w <password> -b "dc=<domain>,dc=local"  "(objectclass=user)"
[Edit]
Solved.
Here are the settings I used to make it work:
define('LDAP_HOST', '<my ldap server>');
define('LDAP_DN', 'DC=<my domain>,DC=local');
define('LDAP_USER', '<a user>');
define('LDAP_PASS', '<a user password>');
And this is where I was going wrong. I thought the LDAP_USERNAME_FIELD should have been "samaccountname" but apparently it needed to be set to "cn". Once I changed that, everything worked. I have no idea why.
//define('LDAP_USERNAME_FIELD', 'samaccountname');
That actually does makes sense. The problem is that LDAP_USERNAME_FIELD is a little misleading as a setting....
cn (Active Directory)
uid (OpenLDAP)
