Transport only works with .com domain not working with .com.ar domain --eFa-3.0.1.9
Dawara
Post by Dawara »
Hi All,
Im adding two domains in Mail transport Settings
1) egxx.com.ar 192.168.x.251
2) esdxx.com 192.168.x.251
only esdxx.com mails pass through
Mails with egxx.com.ar are not working. ( of course DNSs MX's are ok )
When I redirect traffic on the firewall directly to the mail server , both domains are working fine.
Any workaround ?
I've installed eFa-3.0.1.9-VMware
Thanks in advance
Re: Transport only works with .com domain not working with .com.ar domain --eFa-3.0.1.9
What do you see in /var/log/maillog from the domain that is not working?
Dawara
Post by Dawara »
I tested with an smtp telnet session and I get
Recipient address rejected: Domain not found
trying to send to the .com.ar domain
Dawara
Post by Dawara »
in var/log/maillog file there is a bounch of lines with NOQUEUE : Reject RCPT from .......
Can you resolve that domain on the efa from the console?
Dawara
Post by Dawara »
Thank you very much for that reply.
I solve the DNS resolution for that domain from the EFA machine and it is working now ( both domains ) .
So:
If you have 2 or more domains in Transport Settings and one of the is not working, check the DNS resolution for that domain.
