Munin-node and webmin turn off
Posted: 22 Apr 2017 13:50
by BliXem
Is it possible to stop munin-node and webmin? If I stop webmin, it will restarted automaticly:
Service webmin down and restarted ( 1 attempts in past day, max attempts is 3 )
Please examine your EFA logs on mailscanner.wrhg.nl and resources to determine cause of failure.
Re: Munin-node and webmin turn off
Posted: 24 Apr 2017 21:08
Hi Blixem,
If you want to stop and disable Webmin / Munin
To show enabled services:
chkconfig --list
or just webmin
chkconfig --list |grep 'webmin'
show the status
/etc/init.d/webmin status
stop the service
/etc/init.d/webmin stop
disable the service
chkconfig webmin off
check:
Webmin is stopped
and
Posted: 24 Apr 2017 22:44
BliXem wrote: 22 Apr 2017 13:50 Hello,
Place your eFa into Maintenance Mode in EFA-Configure if you want to disable webmin. This will disable EFA-Monitor that is restarting the service.
