Is it possible to stop munin-node and webmin? If I stop webmin, it will restarted automaticly:
Service webmin down and restarted ( 1 attempts in past day, max attempts is 3 )
Please examine your EFA logs on mailscanner.wrhg.nl and resources to determine cause of failure.
Munin-node and webmin turn off
Re: Munin-node and webmin turn off
Hi Blixem,
To show enabled services: or just webmin
show the status
stop the service
disable the service
check:
and
If you want to stop and disable Webmin / MuninIs it possible to stop munin-node and webmin?
chkconfig --listCode: Select all
chkconfig --list |grep 'webmin'Code: Select all
/etc/init.d/webmin statusCode: Select all
/etc/init.d/webmin stopCode: Select all
chkconfig webmin offCode: Select all
Webmin is stoppedCode: Select all
chkconfig --list |grep 'webmin“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
Place your eFa into Maintenance Mode in EFA-Configure if you want to disable webmin. This will disable EFA-Monitor that is restarting the service.BliXem wrote: 22 Apr 2017 13:50 Hello,
