Upgrade from 3.0.1.9 to 3.0.2.1
Posted: 15 Apr 2017 11:58
by bostjanc
Hi guys.
I see this errors after reboot:
Can we ignore?
Re: Upgrade from 3.0.1.9 to 3.0.2.1
Posted: 15 Apr 2017 16:00
yes. Hope to resolve with a clamav unofficial sigs update soon.
Posted: 15 Apr 2017 16:56
by bostjanc
Thanks for the reply and for the all the effort you put in EFA.
with best regards
Posted: 18 Apr 2017 07:54
by AITCS
I noticed this happen in far more versions that just the latest.
Never worried about it as freshclam always worked fine, even via cron.
Happy to see a resolution for it though.
