Upgrade from 3.0.1.9 to 3.0.2.1
bostjanc
Post by bostjanc »
Hi guys.
I see this errors after reboot:
Can we ignore?
Re: Upgrade from 3.0.1.9 to 3.0.2.1
yes. Hope to resolve with a clamav unofficial sigs update soon.
bostjanc
Post by bostjanc »
Thanks for the reply and for the all the effort you put in EFA.
with best regards
AITCS
Post by AITCS »
I noticed this happen in far more versions that just the latest.
Never worried about it as freshclam always worked fine, even via cron.
Happy to see a resolution for it though.
