continue not asking DCC Errors
afternoon
can anyone help with the error "continue not asking DCC", server got hammered earlier and since that i keep getting that error.
Its urgent if someone can help
Re: continue not asking DCC Errors
Did you hit the DCC Clearinghouse free limit threshold (100,000 queries)?
Hi Shawn
Sorry not sure how to check
Let's assume its not that for a moment.
Try running this command to reset the map (I think).
sudo /usr/local/bin/cdcc “load map.txt”
Hi Shaun
Details Below
Details Below
# 04/11/17 14:59:47 BST /var/dcc/map
# Re-resolve names after 16:59:43
# 12 total, 0 working servers
# continue not asking DCC server 30 seconds after 1 failures
IPv6 on version=3
dcc1.dcc-servers.net,- RTT+1000 ms anon
# 74.92.232.243,-
# not answering
# 137.208.8.63,-
# not answering
# 209.169.14.29,-
# not answering
dcc2.dcc-servers.net,- RTT+1000 ms anon
# 67.66.138.141,-
# not answering
# 192.84.137.21,-
# not answering
# 194.119.212.6,-
# not answering
dcc3.dcc-servers.net,- RTT+1000 ms anon
# 209.169.14.27,-
# not answering
# 212.223.102.90,-
# not answering
dcc4.dcc-servers.net,- RTT+1000 ms anon
# 69.12.221.230,-
# not answering
dcc5.dcc-servers.net,- RTT+1000 ms anon
# 136.199.199.160,-
# not answering
# 212.223.15.198,-
# not answering
@,- RTT-1000 ms 32768 secret14216735570y1242
# *127.0.0.1,-
# not answering
# 04/11/17 14:59:47 BST greylist /var/dcc/map
# Re-resolve names after 16:59:47
# 1 total, 0 working servers
# continue not asking greylist server 32 seconds after 1 failures
@,- Greylist 32768 secret14216735570y1242
# *127.0.0.1,6276
# not answeringRe: continue not asking DCC Errors
Wondering if it was the hit i got this morning that has caused it.
Yeah, this looks like you been cut off (hopefully temporarily) from querying DCC, most likely from the volume.
looking at the output, it says
Do you think this is the reactivate time for me to be able to? i've had to blacklist the old customer lol for the time being.
On Another note the Dcc log folder had 30k in files, is there a cleanup job for this folder?
# Re-resolve names after 17:13:50On Another note the Dcc log folder had 30k in files, is there a cleanup job for this folder?
Cheers for the quick replies by the way
, much appreciated
Maybe, I think that will be when the list is refreshed.
Hmm...doesn't appear to be a cleanup for that folder......maybe need to do something there...
Hi Had 30k in files, took ages to list the directory lol
How can i disable dcc for now and maybe activate it tomorrow?
Sorry, missed this post. You can simply shut down the dcc process (sudo service adcc stop).
Could be wrong, but Housekeeping on dcc should be done by /etc/cron.daily/cron-dccd
Where in /var/dcc/dcc_conf
Since EFA is still on Centos6, You can use tmpwatch also to do some housekeeping.
By default, tmpwatch dates files by their atime (access time)
the /var/spool/MailScanner/incoming/SpamAssassin-Temp is perfect candidate for tmpwatch
just add in /etc/cron.daily/tmpwatch at the end:
[root@sansspam cron.daily]# ls -l
total 56
lrwxrwxrwx. 1 root root 26 May 25 2015 cron-dccd -> /var/dcc/libexec/cron-dccd
# days to keep files in DCC log directories
DBCLEAN_LOGDAYS=1
# ----- User defined cleanup-jobs -----
# MailScanner_incoming
/usr/sbin/tmpwatch -u 48 /var/spool/MailScanner/incoming/SpamAssassin-Temp“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
Sure its not a firewall issue?
See also post; viewtopic.php?t=981
