Several Issues with 3.0.7
ramtech
Post by ramtech » 02 Mar 2015 04:27
Hi all,
i have used EFA several time before and love it. I have just installed a new install (VM 3.0.5 upgraded to 3.0.7) and I'm having quite a few issues.
  • No GeoIP Lookups succeed.
  • Clamd was failing causing the emails to just keep reappearing back in the list and never delivering
  • Lots of false positives with the defaults (Normally we find it excellent out of the box with only a few tweaks needed)
I haven't been able to solve the GeoIP issue yet. This is my main question.
The Clamd issue was a bit confusing. Before I knew it was Clamd causing the issue, I restarted the whole VM. No joy. I restarted mailscanner with still no joy. I searched the /var/log/mailog to find a fair few Clamd errors (46000 to be precise). I restarted the Clamd daemon and it failed to stop, but started up again okay. After this mail started being processed correctly. The 70 emails that had been received turned into 6.5Gb and 50000 emails processed and finally fell into the end user mailboxes.
The false positives, i will have to starting checking one by one and find out what is going on and why we suddenly have some many issues.
So question one is, any suggestions on how to fix the GeoIP lookups? {Solved! See edits below} :arrow:
Question two is, any known reason why we would be having more FP issues than previous versions.
Edit:
I have just found this in a SpamAssassin Lint Test..
metadata: RelayCountry: failed to load 'Geo::IP', skipping: Error opening /usr/local/share/GeoIP/GeoIP.dat at (eval 46) line 4973, <DATA> line 717.
Any guesses what this means? This file doesn't exist on my system as it seems to be a symbolic link to /var/www/html/mailscanner/temp/GeoIP.dat which isn't there. How can it evaluate it and fail at a line number if it isn't there?
Another Edit:
I have re downloaded the GeoIP Database from the GUI. I restarted the MailScanner service and re-ran the SA Lint test (No errors this time). This seems to have resolved the GeoIP issue for anyone's future reference.
So apart from the lots more FPs, all my questions seem answered (by me :) ) now. Any help with the FPs would be appreciated.
Re: Several Issues with 3.0.7
Post by shawniverson » 02 Mar 2015 18:54
Can you share a spam report on one of the FPs?
As for clamd issue, how much memory does your EFA have?
ramtech
Post by ramtech » 02 Mar 2015 19:37
Hi Shaun,
1GB RAM on the VM. It is the 3.0.5 VM downloaded from one of the mirrors.
I will get a Spam report and forward it through. as soon as I am back there.
darky83
Site Admin
Post by darky83 » 02 Mar 2015 19:39
1GB ram is just not enough, 2GB is the minimum but 4GB is recommended.
Out of the box we have configured the machine with 2GB, and from 3.0.0.7 and forward this will be 4GB
Try increasing your memory to 4GB :)
Version eFa 4.0.1 now available!
ramtech
Post by ramtech » 02 Mar 2015 19:54
Ta Shawn.
I hadn't read that anywhere so just left the standard. (It was at 2GB btw)
I have upped it to 4Gb now so we'll see how that goes.
ramtech
Post by ramtech » 04 Mar 2015 05:59
It's a bit more stable now with 4GB. I've booted it a few times and all okay, so I assume you're correct Shawn. The Clamd issue was insufficient RAM.
My current dilemma is /var/log/maillog filling up with the following...
Mar  4 15:14:54 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:14:56 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:14:59 MPHOEFA dccifd[1230]: continue not asking DCC 59 seconds after 2 failures
Mar  4 15:15:01 MPHOEFA dccifd[1230]: continue not asking DCC 57 seconds after 2 failures
Mar  4 15:25:50 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:27:52 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:31:27 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:33:51 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:33:59 MPHOEFA dccifd[1230]: continue not asking DCC 24 seconds after 1 failures
Mar  4 15:34:07 MPHOEFA dccifd[1230]: continue not asking DCC 16 seconds after 1 failures
Mar  4 15:43:46 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Mar  4 15:46:22 MPHOEFA dccifd[1230]: no working DCC servers dcc1.dcc-servers.net dcc2.dcc-servers.net dcc3.dcc-servers.net ... at 137.208.8.63 74.92.232.243
Any suggestions on that one? I assume some sort of firewall issue but can't find any info on what protocol or ports it's trying to talk on.
Edit:
Found it on another forum. The following ACL on my Cisco solved my problem...
permit udp any eq 6277 host <my.ext.ip.add> gt 1023
darky83
Site Admin
Post by darky83 » 04 Mar 2015 18:14
Bit late response :) but its also in the wiki, make sure you have all the needed ports open.
https://efa-project.org/wiki/FAQ#What_f ... _needed.3F
ramtech
Post by ramtech » 04 Mar 2015 22:10
Thanks for that. I looked in the wiki but obviously had a man look. Sorry.
For any other Cisco ISR users out there that are hiding behind ACLs, as opposed to CBAC or ZBFW I had to do the following on my IN WAN ACL...
ip access-list extended aclInternetInbound
 permit tcp any any established
 permit udp any eq 6277 host <WAN.EXT.IP.ADDR> gt 1023
 permit udp any eq 24441 host <WAN.EXT.IP.ADDR> gt 1023
 ... ! the rest of your ACL
interface <WAN.INTERFACE>
 ip access-group aclInternetInbound in
