EFA as outgoing relay / smarthost
Alex
Post by Alex »
it is possible to use efa as outgoing relay / smarthost?
Additionaly it would be fine to use certificates (smime) for signed outgoing mails.
Best regards
Alex
darky83
Site Admin
Re: EFA as outgoing relay / smarthost
Post by darky83 »
Expect this to be working in 0.3.
You can already use it but you will need to do a few manual steps until 0.3 is released:
as root do the following:
First configure postfix:
postconf -e smtpd_recipient_restrictions="permit_sasl_authenticated, permit_mynetworks, reject_unknown_recipient_domain, reject_unauth_destination, whitelist_policy, rbl_policy, spf_policy"
Then download the current development version of EFA-Configure:
cd /tmp
wget https://raw.github.com/darky83/EFA/master/Build/0.3/usr/local/sbin/EFA-Configure.bash
chmod 700 EFA-Configure.bash
./EFA-Configure.bash
You will see the option to allow specific hosts/subnets for outgoing relay.
Note that the script is still a work in progress so you can expect some bugs :P
blason
Post by blason »
Nope, I tried applying the change but result the same. Its not allowing me to relay
blason
Post by blason »
Ok - finally I got it working ;)
Since I was using webmail, I was single host but strangely it wasnt accepting and was getting RELAY ACCESS. Then I added entire network and doh it accpeted, could that be bug?
DavidRa
Post by DavidRa »
blason wrote:Ok - finally I got it working ;)
Perhaps it is a bug. One way to specify a single host (but make it look like a network) would be something like this:
10.29.54.73/32
It might be worth a try if you wanted to secure relay through EFA? Also, were you adding the mail server's IP address to the list of allowed IPs, or your workstation? One assumes the server, but it's always good to double check these things.
blason
Post by blason »
nah even that didnt work and postfix stopped responding with a fatal error says 192.168.1.32/32 is not a valid host perhaps you should try adding entire network
Alex
Post by Alex »
Thanky,
and automatic smime signing?
is this feature working?
blason
Post by blason »
I use zimbra inside. How do I check that? In headers
darky83
Site Admin
Post by darky83 »
Alex wrote:Thanky,
I have encryption (ssl, S/MIME) on the roadmap for a later release so no not yet functional.
Alex
Post by Alex »
This feature is very important...
frderi
Post by frderi »
I would be interested in trying this functionality since it would allow me to add a banner at the bottom of each outgoing email. Would it be possible to have a FAQ of somesorts that explains how to do this in 0.3 ?
Thanks! :)
