EFA Minimum requirements?
telvenes
Post by telvenes »
I have read this:
https://wiki.efa-project.org/doku.php?id=setup_guide
Is minimum requirements 8gb of ram?
darky83
Site Admin
Re: EFA Minimum requirements?
Post by darky83 »
Yup, for a small install you could get by with just 4gb but 8gb should be your starting point if you use it for a number of domains.
e-d-i-t
Post by e-d-i-t »
I've been live now with 2GB RAM on Hyper-V and 2 vcpu's.
Webmin is showing a stable 61% usage on RAM.
Processing up to 500 mails an hour is very small, but let that be an indication of my very small setup.
If it would be at the office, ofcourse it will be 8GB/4cpu ;-)
