i want to block email with the word "bounce" or "bounces" in the field "From"
I've found this thread
viewtopic.php?f=14&t=1284&p=4617&hilit=bounce#p4617
but I am not sure that the instructions are still correct, because I saw that now this type of instruction is stored in the /etc/MailScanner/rules or MCP folders. So I tried to create rules to be included as MCP but messages with "bounce" in from are not locked, their MCP score is equal to 0.
Thank you
Samuele
Block email with "bounce" in from
Re: Block email with "bounce" in from
hello,
dont work with every messagges but block a good number of spam email
header BOUNCE_IN_HEADER ALL =~ /bounce/i
score BOUNCE_IN_HEADER 10
describe BOUNCE_IN_HEADER bounce keyword in from address
header BOUNCES_IN_HEADER ALL =~ /bounces/i
score BOUNCES_IN_HEADER 10
describe BOUNCES_IN_HEADER bounces keyword in from address
