I'm new in EFA, after update to version 3.0.1.8 and when MailScanner restart follow message appears:
Could not use Custom Function code MailScanner::CustomConfig::InitSQLBlacklist, it could not be "eval"ed. Make sure the module is correct with perl -wc (Error: DBD::mysql::st execute failed: Illegal mix of collations (utf8_general_ci,IMPLICIT) and (utf8_unicode_ci,IMPLICIT) for operation '=' at /usr/share/MailScanner/perl/custom/SQLBlackWhiteList.pm line 142.
) at /usr/share/MailScanner/perl/MailScanner/Config.pm line 1053
Someone can explain to me how to fix this warning?
Thank you
Samuele
Warning after restart MailScanner
Re: Warning after restart MailScanner
So I had this too on a fresh install and couldn't find any solution. I finally tracked down a solution, whether it is the correct solution not sure. Basically the database encoding has changed and depending on what version of mysql determines what format. For whatever reason it looks like things are jacked up.
My fresh install has mysql version 5.1.73 (mysql --version) so it doesn't support the latest unicode version. I tracked down the upgrade scripts in the mail watch tools repository:
https://github.com/mailwatch/1.2.0/tree ... 8_Database
Running this one solved my problem:
https://github.com/mailwatch/1.2.0/blob ... o_utf8.sql
If you have mysql version 5.5.3 or newer then this should probably do the trick:
https://github.com/mailwatch/1.2.0/blob ... tf8mb4.sql
I ran the script from Navicat mysql client but you should be able to do this from terminal.
Hope this works for you.
What version of did you use for the "fresh install"? I verified that all tables are utf8_unicode_ci in both the VM and the upgrade.puffen wrote: 11 Feb 2017 18:55 So I had this too on a fresh install and couldn't find any solution. I finally tracked down a solution, whether it is the correct solution not sure. Basically the database encoding has changed and depending on what version of mysql determines what format. For whatever reason it looks like things are jacked up.
Good question. Now that I'm looking at my image repository, I believe I took the CentOS-6.8-x86_64-minimal.iso and used the kickstart script.
Re: Warning after restart MailScanner - whitelist not working
i'm facing to this too:
and whitelist was not working.......
this happens after i use listimport.sh to replace my whitelist
the script maybe drops the tables and recreates them as utf8_general_ci (could be some default in mysql?)
in my case:
whitelist/to_address
whitelist/to_domain
whitelist/from_address
after changing them back to utf8_unicode_ci all works well again.
i'm still on 3.0.1.8, so this is maybe corrected in later versions
jens
Restarting MailScanner ...
Could not use Custom Function code MailScanner::CustomConfig::InitSQLWhitelist, it could not be "eval"ed.
in my case:
whitelist/to_domain
jens
Adds to my todo list...
