We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed (hopefully) in 3.0.1.6:
Issue #263 Bug - Postfix Install Mangling of main.cf
Issue #326 Bug - MCP not functional
Issue #328 Bug - ClamAV Not Updating
Issue #331 Enhancement - Move Version into MailWatch
PR #332 Bug - Increase the number of characters allowed for the TLD
Issue #334, #234, #212 Bug - MailWatch Update
Issue #335 Bug - EFA-Configure Recusion Toggle Broken
Issue #340 Bug - Inline Signature bug in EFA-Configure
Issue #341 Bug - LANG option missing in MailWatch update
3) If the update fails for any reason, collect relevant logs or screen
outputs/screenshots and revert to your snapshot
Launch EFA-Configure from console or secure shell
(sudo /usr/local/sbin/EFA-Configure)
Choose option 14) Update Now
continue the update process to 3.0.1.6.
if present.
After updating, please run "Update GeoIP Database" update as soon as
possible from MailWatch under Tools/Links.
