E.F.A. 3.0.1.6 Beta Released!
Posted: 17 Dec 2016 17:08
The 3.0.1.6-beta update is now available for BETA TESTING ONLY. DO NOT USE IN PRODUCTION.
We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed (hopefully) in 3.0.1.6-beta:
Issue #263 Bug - Postfix Install Mangling of main.cf
Issue #328 Bug - ClamAV Not Updating
Issue #331 Enhancement - Move Version into MailWatch
PR #332 Bug - Increase the number of characters allowed for the TLD
Issue #326 Bug - MCP not functional
Issue #335 Bug - EFA-Configure Recusion Toggle Broken
Issue #334, #234, #212 Bug - MailWatch Update
Issue #340 Bug - Inline Signature bug in EFA-Configure
Issue #341 Bug - LANG option missing in MailWatch update
To participate in the beta testing, execute the following on your existing EFA to update to the beta (as root):
To test a build from scratch, use the following kickstart script using CentOS 6.8:
http://dl.efa-project.org/build/3.0.1.6-beta/ks.cfg
WARNING: You will not be able to upgrade from this beta to the next production version. Beta testing only!
wget https://dl.efa-project.org/update/EFA-update-script-3.0.1.6-beta
chmod u+x EFA-update-script-3.0.1.6-beta
sudo ./EFA-update-script-3.0.1.6-beta
