We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed (hopefully) in 3.0.1.6-beta:
Issue #263 Bug - Postfix Install Mangling of main.cf
Issue #328 Bug - ClamAV Not Updating
Issue #331 Enhancement - Move Version into MailWatch
PR #332 Bug - Increase the number of characters allowed for the TLD
Issue #326 Bug - MCP not functional
Issue #335 Bug - EFA-Configure Recusion Toggle Broken
Issue #334, #234, #212 Bug - MailWatch Update
Issue #340 Bug - Inline Signature bug in EFA-Configure
Issue #341 Bug - LANG option missing in MailWatch update
To participate in the beta testing, execute the following on your existing EFA to update to the beta (as root):
wget https://dl.efa-project.org/update/EFA-update-script-3.0.1.6-beta
chmod u+x EFA-update-script-3.0.1.6-beta
sudo ./EFA-update-script-3.0.1.6-beta
http://dl.efa-project.org/build/3.0.1.6-beta/ks.cfg
WARNING: You will not be able to upgrade from this beta to the next production version. Beta testing only!
