postscreen!
SupportOU
postscreen!
Post by SupportOU »
Hola,
What about setting up postscreen on the border instead of the postfix daemon? This will anyway make sure encryption is used and postscreen is specifically built to be on the border.
I could create a master.cf template I guess. And the main.cf to go with that.
Grtz,
Ronald
Re: postscreen!
Postscreen is a part of postfix, so yes, I intend to build this in as an option.
bipsen
Re: postscreen!
Post by bipsen »
shawniverson wrote:Postscreen is a part of postfix, so yes, I intend to build this in as an option.
iRedMail also uses postscreen - inspiration could come from there as well (I have a test-system running with iRedMail - so I can grab some info from there)...
/B
SupportOU
Re: postscreen!
Post by SupportOU »
Any info welcome, though I don't think it is very hard to add this to our existing mix. But if you can spare the master.cf and main.cf from that (or just the relevant portions), just post!
Grtz
bipsen
Re: postscreen!
Post by bipsen »
I am no expert in postfix, but I will try to attach the files once I've cleaned them from config stuff from my setup...
iRedMail also uses amavisd - so some minor tweaks are probably needed for that part....
bipsen
Re: postscreen!
Post by bipsen »
main.cf and master.cf
Let me know if other info is needed....
postfix-iRedMail.zip
(5.92 KiB) Downloaded 954 times
Re: postscreen!
