Errors when checking PDF content
Today I saw this in logs:
Nov 19 09:29:38 mailfilter-in MailScanner[4288]: Clamd::ERROR:: yy1.pdf/Access denied. ERROR :: ./0E75E100907.A0A5E/tnefGK2zbT
Nov 19 09:29:38 mailfilter-in MailScanner[4288]: Clamd::ERROR:: xx2.pdf/Access denied. ERROR :: ./0E75E100907.A0A5E/tnefGK2zbT
Nov 19 09:29:38 mailfilter-in MailScanner[4288]: Clamd::ERROR:: xx1.pdf/Access denied. ERROR :: ./0E75E100907.A0A5E/tnefGK2zbT
Is there something to be done?
Re: Errors when checking PDF content
Are these encrypted and/or password protected?
we have the problem that password protected PDF files git banned. How can i change this behaviour ?
Best wishes
Niels
Best wishes
Niels
this is the message:
Our content checker found
virus: Heuristics.Encrypted.PDF
That's coming from ClamAV.
Is this set to no in /etc/MailScanner/MailScanner.conf?
Block Encrypted Messages = no
yes. it is set to no.
In /etc/clamd.conf:
# Mark encrypted archives as viruses (Encrypted.Zip, Encrypted.RAR).
# Default: no
ArchiveBlockEncrypted no
it is set like you posted
# Default: no
# Default: no
Seems to be an issue with the clamav 0.99.2
Might try this...
Might try this...
sudo echo "Heuristics.Encrypted.PDF" >> /var/lib/clamav/local.ign2
sudo service clamd restart
hi,
i did. I see this:
[root@defender defendersf]# echo "Heuristics.Encrypted.PDF" >> /var/lib/clamav/local.ign2
[root@defender defendersf]# sudo service clamd restart
Stopping Clam AntiVirus Daemon: [ OK ]
Starting Clam AntiVirus Daemon:
LibClamAV Error: yyerror(): /var/lib/clamav/antidebug_antivm.yar line 497 undefined identifier "pe"
LibClamAV Error: cli_loadyara: failed to parse rules file /var/lib/clamav/antidebug_antivm.yar, error count 7
LibClamAV Error: yyerror(): /var/lib/clamav/winnow_malware.yara line 65 duplicate identifier "CryptoWall_Resume_phish"
LibClamAV Error: yyerror(): /var/lib/clamav/winnow_malware.yara line 83 duplicate identifier "docx_macro"
LibClamAV Error: cli_loadyara: failed to parse rules file /var/lib/clamav/winnow_malware.yara, error count 2
[ OK ]
Best wishes
Niels
i did. I see this:
[ OK ]
Best wishes
Niels
You can ignore those errors. They are yara rules that are only applicable on windows.
Hi, encrypted files get still blocked.
How can i remove this encrypted block completely ?
THX and best wishes
Niels
THX and best wishes
Niels
