You're right.
My provider also checks spf and put it in the header.
Can you share your script for the check?
Message 1:
Received-SPF: pass (s01.spamexperts.axc.nl: domain of marktplaats.nl designates 5.255.156.8 as permitted sender) client-ip=5.255.156.8; envelope-from=
automatisch@marktplaats.nl; helo=marktplaats.nl;
X-SPF-Result: s01.spamexperts.axc.nl: domain of marktplaats.nl designates 5.255.156.8 as permitted sender
Authentication-Results: s01.spamexperts.axc.nl; dmarc=pass header.from=marktplaats.nl
Complete header message2:
Received: from s02.spamexperts.axc.nl (s02.spamexperts.axc.nl [159.253.1.250])
by xxxxxxxxxx(Postfix) with ESMTPS id 37608100B35
for xxxxxxxxxxxx; Fri, 21 Oct 2016 07:59:47 +0200 (CEST)
Received: from mta10d9.r.grouponmail.nl ([50.115.219.10])
by s02.spamexperts.axc.nl with esmtps (TLSv1.2:ECDHE-RSA-AES256-GCM-SHA384:256)
(Exim 4.86)
(envelope-from <
5cf67db1b491e9c181be19c20a17aa62e388e3ba10369e8c763f144d62dfc1c4@bounce.r.grouponmail.nl>)
id 1bxSrp-0004QX-QF
for xxxxxxxx; Fri, 21 Oct 2016 07:59:47 +0200
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=r.grouponmail.nl;
s=s1024d20130206; t=1477029525;
bh=5FakkmE9fXfMCRusdwqmAiQLsCHhSKgvsBGkLeIihKs=;
h=Date:From:To:Message-ID:Subject:Content-Type;
b=oLORTgtV8H1wbLXMeA9ctPZn/1/bnc2ngVMnsmpIVSfOtAWPfP0JLpRevOaajF6lc
ywW3bdAr+rA1O0DOke50+YTgSbJcNAy8K4SBaOVX4SJv/1xsrZmvMG1K7JhxXLiB1b
aDaHBicoBq5DfF0jg21ktJP8bhbKgIahpdPN8dYw=
Date: Fri, 21 Oct 2016 05:58:45 +0000
noreply@r.grouponmail.nl>
To: xxxxxxxxx
Message-ID: <1587218693.1102875.1477029525209.JavaMail.rocketman@push-dispatcher2>
Subject: Refurbished iPhone 5c/5/5S/6, iPhone 6 refurbished, Slimming Sauna
tailleband, Connected Smartwatch compatibel met Android en iPhone & meer
MIME-Version: 1.0
Content-Type: text/html; charset=UTF-8
Content-Transfer-Encoding: quoted-printable
X-RM-UserHash: 5cf67db1b491e9c181be19c20a17aa62e388e3ba10369e8c763f144d62dfc1c4
X-RM-SendId: c7abea3c-c74b-4138-826c-9509dea3568e_0_20161021
X-RM-SenderScore: 90
X-RM-EmailName: channel-goods_auto_nl_im_channel-goods_landelijke-deal_nl_im_goods_SD_PMP
X-MSFBL: bWFyamFuLnBpZXRlcm1hbkBwYXN3ZXJrLm5sOmJhdGNoOmM3YWJlYTNjLWM3NGItNDEzOC04MjZjLTk1MDlkZWEzNTY4ZV8wXzIwMTYxMDIxOjg4NTUwMjg4Ok5M
List-Unsubscribe: <mailto:
5cf67db1b491e9c181be19c20a17aa62e388e3ba10369e8c763f144d62dfc1c4@unsub.r.grouponmail.nl?subject=bWFyamFuLnBpZXRlcm1hbkBwYXN3ZXJrLm5sOmJhdGNoOmM3YWJlYTNjLWM3NGItNDEzOC04MjZjLTk1MDlkZWEzNTY4ZV8wXzIwMTYxMDIxOjg4NTUwMjg4Ok5M>
X-RPCampaign: GrouponchannelgoodsautonlimchannelgoodslandelijkedealnlimgoodsSDPMP20161021
X-RPTags: channel-goods_auto_nl_im_channel-goods_landelijke-deal_nl_im_goods_SD_PMP
X-Recruiting: Interested in headers? Join us:
www.groupon.com/techjobs/
List-Id: <channel-goods_auto_nl_im_channel-goods_landelijke-deal_nl_im_goods_SD_PMP_20161021.groupon>
X-Feedback-ID: r.grouponmail.nl:channel-goods_auto_nl_im_channel-goods_landelijke-deal_nl_im_goods_SD_PMP:c7abea3c-c74b-4138-826c-9509dea3568e_0_20161021:groupon
Received-SPF: pass (s02.spamexperts.axc.nl: domain of bounce.r.grouponmail.nl designates 50.115.219.10 as permitted sender) client-ip=50.115.219.10; envelope-from=
5cf67db1b491e9c181be19c20a17aa62e388e3ba10369e8c763f144d62dfc1c4@bounce.r.grouponmail.nl; helo=mta10d9.r.grouponmail.nl;
X-SPF-Result: s02.spamexperts.axc.nl: domain of bounce.r.grouponmail.nl designates 50.115.219.10 as permitted sender
Authentication-Results: s02.spamexperts.axc.nl; dmarc=pass header.from=r.grouponmail.nl
X-Filter-ID: s0sct1PQhAABKnZB5plbIXbvVvfo0PIvAcbsTOKi5vApA/3P63BXZK0InpHZdJ8dSLobrTqf3Lrx
Gpnzah0qdaZSKIZ97UxKgsaktkDJND4nzoduOs+O63vgSQMF2XoQ83mXiYPkQwZ7twwjILjl1nF9
Q7Csa36kseD2MRENRBoTiLpMAlqkbTZVzn9dr+kXg1IuV8rTh3xoEFxB8JZlp0xgrB5DAFKeAfk/
k5oBMgBrnmzOz1Q/JhgM4VSHPfty97n4n8t1fwXDHJ6bxPFQEU2lxSMkPwz4aCrDnbcXrp/09mVT
v4ED3fe4cLUAa6OMuRzc7ILb/NdibT048mMRsaz8uRHVDm4oL3YFI3MCMlUhu1/rdU1t/SWu+yxj
6TsAcIIuBvXuufB2oYN7GM2Kri1TuO7JmFijQ8sPS8/019HZCr33UOmLBUGvzrsM+6rYj7kxzD2Y
SQadThILqbNNMhnis/L5RJfxkhIgp8XOgK0D/KWp4AnHMHjTUaG+xEMBeH9lQ9qpNa3eXZMS8sKW
BGYzx2Zgyhf3OXiddZgacWeUj9K5LHqghaawncs+AEpJoX8xI8inIGOdjCDQz8eCjtaMKj+lYJrN
bK2NLL7wZuXzqJS3lGmjIyiogf39oXs+SF2fA+4+A4ApWBtH6Wl/W67U25OUkChc89La5MsdjsRO
h/6XX0s2Z4LriFwHSpKjMS+4ayUpOtEhdxekWDmK9g==
X-Report-Abuse-To:
spam@s01.spamexperts.axc.nl
Authentication-Results: spamexperts.axc.nl; spf=pass smtp.mailfrom=
Authentication-Results: spamexperts.axc.nl; dkim=pass header.i=r.grouponmail.nl
X-SpamExperts-Class: ham
X-SpamExperts-Evidence: dnswl/ip-09.rbl.spamrl.com
X-Recommended-Action: accept
