Greetings from SoCal's Inland Empire
New users please present your self here (no real names needed) so we can prevent spam bots.
BDKaatz
Post by BDKaatz »
Greetings folks,
I got tired of Symantec's Messaging Gateway (a.k.a. BrightMail) removing valid emails due to their Global Bad Senders List that apparently is based solely on domains. They have already added @icloud.com as well as @usdoj.gov, and since there is no transparency into that list, there is nothing that can be done except turn off that check completely. Of course, if you do that, you will likely be slammed with the crud that it *was* properly removing.
The fact that last month, Symantec stated they are dropping support for SMG in the next two years, meant we were going to have to switch to something else anyway and I enjoy using and supporting open-source projects whenever I can.
So thank you for this project and I will be talking with you soon.
/bk
________________________
"I do not feel obliged to believe that the same God who has endowed us with
sense, reason, and intellect has intended us to forgo their use."
-- Galileo Galilei
Re: Greetings from SoCal's Inland Empire
:text-welcomewave:
