*** Referenced White List [score enhancement] ***
Post by nicola.piazzi »
I suggest to anyone any simple enhancement that can help to find really ham messages.
When you send a message to someone ant this people answer it you are sure that this is ham and the couple EmailAddress/ServerIp is candidate for whitelisting.
Some server, when message is a answer, put in header one or both keyword like this :
In-Reply-To: <df83b29d208f4f53b6db032be12b0126@yourdomain.it>
References: <df83b29d208f4f53b6db032be12b0126@yourdomain.it>
So it is very simple to make a rule that check that the incoming message contains a reference to your domain adding these lines to local.cf, obviosulsy changing domain list :
# BONUS TO MESSAGES THAT ARE REPLIES TO A MESSAGE SENT FROM US
header __REPLY_TO_US_REFERENCES References =~ /\@mydomain1.it|\@mydomain2.it/i
header __REPLY_TO_US_INREPLYTO In-Reply-To =~ /\@mydomain1.it|\@mydomain2.it/i
meta REPLY_TO_US ( __REPLY_TO_US_REFERENCES || __REPLY_TO_US_INREPLYTO )
describe REPLY_TO_US Was a reply to a message sent from us
score REPLY_TO_US -2.90
Someone can tell that also a spammer can add a line like above containing this code, obviously the better il will be to make a database of message numbers sent and find for a match every time, but in my tests of a lot of days i never found a spam that have REPLY_TO_US in its report, I think that spammers can't say that someone run a test like so and put a dummy tag to pass this kind of check.
Better is to use these data to compile a whitelist of people that have answered to our messages.
To do that please follow these steps :
1) Create a folder called /batch and put in it 2 files contained in the attachment rrwl.zip, chmod to enable execution.
2) Put in your CRONTAB these 2 lines :
05 00 * * * /batch/rrwl.sh
05 01 * * * /batch/rrwl.cf.sh
(rrwl.sh runs after midnight and create 2 files of referenced email (one domain based and one email based) with Yesterday data,
rrwl.cf.sh runs after 1 hour and create .cf files and put in production)
3) Edit rrwl.sh and watch at # Variables, you MUST review mydomains array data and put domains that you use, you MUST review also LDIP writing your internal Ip/Class, Others are optional.
4) Edit rrwl.cf.sh and watch at # Variables, you MUST review singledomains array data and Scores, Others are optional.
singledomains array is very important, it tell if a row will be put as single entry in rrwl.email.cf because it is a public provider or if it will be put in rrwl.domain.cf enabling whitelist on entire domain.
Tell me about your results !
rrwl.zip
(2.83 KiB) Downloaded 348 times
Re: *** Referenced White List [score enhancement] ***
Please redownload rrwl.zip
I changed something in rrwl.sh to prevent some erroneus whitelist to be extracted
I noticed that it is very difficoult to have a hit on rrwl.email.cf
This is because single email that use a provider is more probable that can came from a lot of different ip
So, to save cpu, can be useful to comment the mv of rrwl.email.cf at the end of rrwl.cf.sh script and remove rrwl.email.cf from spamassassin dir.
Perfect Result !
This is about my RRWL Idea results
I am using only domain whitelist, single mail whitelist belongs to email providers (manually declared) but have no hit
I have a whitelist based of 30 days of data collected but in future can increase a bit
Today I received 2.572 messages and this rule hit 445 messages ! more than 17 % of incoming messages that in future can be more than 20%
And all these messages are absolutely ham
NEW VERSION
I made a little thing to avoid a problem of some erroneus matching, please dowlnload new zip
rrwl.02.zip
(3.01 KiB) Downloaded 314 times
New release
Using these files it create rules using C CLASS instead of IP
It give more chances to whitelist sender (whitout false positive)
now i have a hit on 20% of incoming email !!
rrwl.03.zip
(3.18 KiB) Downloaded 326 times
