Reduce false positives
teknikl
Post by teknikl »
Is there a way that I can have EFA deliver(with subject line change) up to let's say 7.0 score and quarantine higher? I can't seem to find those settings anywhere.
Re: Reduce false positives
2227 # This replaces the SpamAssassin configuration value 'required_hits'.
2228 # If a message achieves a SpamAssassin score higher than this value,
2229 # it is spam. See also the High SpamAssassin Score configuration option.
2230 # This can also be the filename of a ruleset, so the SpamAssassin
2231 # required_hits value can be set to different values for different messages.
2232 Required SpamAssassin Score = 4
2233
2234 # If a message achieves a SpamAssassin score higher than this value,
2235 # then the "High Scoring Spam Actions" are used. You may want to use
2236 # this to deliver moderate scores, while deleting very high scoring messsages.
2237 # This can also be the filename of a ruleset.
2238 High SpamAssassin Score = 7
Adjust as you see fit.
